No Start, looking for new Starter Motor
Yours is a Spoked flexplate.
A spoked flex, allows you to see the torque convertor behind it. Which the solid doesn't and the solid doesn't have rivets showing.
Be warned that doing this will allow the car to start in gear.
90-93 Automatic Transmission intermittant NO Start Fix - Topless Rabbit Forums
Briano1234 said
Have you tried the no-start when warm or cold fix.
Hmm guess that's one solution, mines a 91 digifant auto. Look a lot of work to get to the relays or is there a simple way?
Relays are on the knee-bar not in the fuse panel.
You will locate the ignition switch loom on the steering shaft after the shaft covers.
Un-wind the red/black wire on the relay marked 92 (it is the only large red/black wire on it ) from the loom then route it over the steering column and splice it in to the red and black wire that goes back to the switch. This is only energized at the start switch position, and will allow the Key to then engage the hot start relay, and start your car.
Guess I'll have to do this bypass before trying to go for a drive again.
There is the possibility that the Brushes on the side of the selector lever break off and fall over the electric control slider it is then pushed up and under the interlock switch in the park position preventing the contacts from making, as theuy become an insulator.
Cleaning that slider and the upper parts of the slider base usually clears this condition up. When this happens it will usually start when in Neutral, if it still doesn't start then do the by-pass.
If you don't have the heat shield surrounding your starter, you need to source one or insulate it with heat resistance thermal wrap. Even if you have it in stalled you need to install the heat soak relay.
If you want a reliable car (auto's specifically) don't wait.
Heat soak fix.
http://cabby-info.com/Files/InstallingHot-startRelay.pdf
Crimp by-pass fix:
Briano1234 said
You don't have to lower it, find the butt end of the loom on the shaft. unwind the black red cut the end attach the crimp on the engine side of the loom and then locate the relays on the back side of the knee bar cut the red black wire connect the two and you are good to go.
Ok on my way to do the fix today but are a little nervous. Just so I understand you cut the wires and join them togheter with a connector? Tape up the lose ends and that's it?
Like this picture?
Last edit: by SuperDOS
jazzydog said
I had similar trouble with my auto, after rebuilt starter motor and heat soak relay, it turned out to be the actual ignition switch itself. Replaced that and all is well.
I'll 2nd that, many moons on a manual 1.3 Driver had symptoms of a duff/dying starter motor but frigging the wiring alsways ran the motor.
Think back then was less than tenner at main dealer for the switch under the ign lock. Pretty easy to swap, ignore the cobblers in the Hyanes book of lies about drilling the steering lock.
