Gear Box upgrade
Can a 1.8 carb drive a 1.8 GTI Gearbox?
the flanges can be swapped for the ones on your old box so your 90mm shafts fit and will probably need the seals doing anyway, or buy 100mm shafts and hubs.
020 Flange
the clutch will fit but should use a 210mm clutch with 9 bolt flywheel but you should have that if its from the 1.8.
Regional Host NE
Re:
Hi mate its Paul nicci says she is unsure do you want to give me a ring on 07739608140 message to Zodsporttrucker said
That gearbox will bolt on the engine and fit in the car with no problems,
020 Flange
Sent from my SM-G955F using Tapatalk
I found an interesting upgrade for those who don't have a FD type gearbox ;
https://www.eurosporta…ns/mk1/products/16420diff
LIGHTER IS FASTER !!!
I was also told the original clutches can be hammered up to about 150bhp but after that you need to get a heavier duty clutch. I have a bigger clutch already but just curious to know the limits of the 020 in bhp? Does anybody know? Thanks
