Supersprint wanted please - Forget that, now have a Powersprint
Pistol said
Keep us posted on the fit of the manifold once you get it all delivered.  I am looking at their 16v conversion manifold for the next project resto, and will mate it up to the same 60mm system I have on the red one (and which you've just ordered!).
 Will do. Unless anybody had a better idea I think I'll put the two spare heads I have side by side on a bench and bolt the new 4-2-1 onto one and the traditional oe setup onto the other to compare. This could also be the easiest way of allowing the exhaust specialist to measure up too as there's a good chance they'll be unfamiliar with the modification specific to this setup.
 Black 1984 MK1 Golf GTI Campaign.
adi3390 said
Looks right to me. Just bear in mind 60mm is a tight fit and that manifold will need modification for the extra room like mine
Otherwise exactly the same setup as I run!
If there wasn't the lockdown and you weren't so far I'd bring mine down so you could have a listen
 Morning Adi, I'm going to take the manifold to an exhaust specialist next week to get a price for the modification. Just to confirm, your guy to 10mm at the flange end off?
You can also have a look at RC racing exhausts (Iresa) , i have their complete exhaust , and the quality is there.
Last edit: by cdrik915
LIGHTER IS  FASTER !!!
Re:
Morning Dave, flange cut off, 10mm taken off and flange reattached
'83 MK1 Golf GTI
'02 Land Rover Discovery 2 Td5
'08 Audi S3 2.0 16v TFSI
 Looks very nice indeed!
 many thanks, nothing left now than to cut up a perfectly good exhaust!! If the guy let's me I'll film it and post it.
Last edit: by Campaigning for Dave
Ok, so finally managed to get all of the ducks in a row to get the Powersprint system fitted. The 4-2-1 manifold was a bit of a pain to modify as I had to take it to the exhaust shop for them to cut and as the cat wasn't there, there was a fair bit of back and forth to make sure that the finished angle was going to be correct once welded up. I also needed to clean up the welds a little with the dremel but that was no real drama as it only took a few minutes.
C8B2AC72-3048-4189-BE04-1D8289E440EA.jpeg 51C56EE8-94C3-4D39-B982-081B6CF21CA7.jpeg 075CFC09-9D4E-4D70-AB67-587505972D94.jpeg
Even after the 10mm increase in clearance I wanted to be doubly safe so wrapped the entire manifold as I really don't want to have any safety concerns or take it out again any time soon!
005741D3-86A1-41C1-B5A3-938E79F4D889.jpeg 73DC95FA-A443-42BC-B37B-BE75901D180A.jpeg A348B0AA-02AA-4A2F-BFF3-F384DEA91D36.jpeg 38DA8495-F307-4A9C-9B1C-3E48F397EDEA.jpeg 8537C196-DF30-4340-BA59-E3384FAB723B.jpeg
Worth also mentioning that there's a fair bit of the underside of the car that needs to come off the get that manifold in. All pretty straightforward though, just the anti roll bar and gearbox linkage bracket.
427742B3-457E-4F67-AB10-FD3E897DA1D0.jpeg B0826EF1-76E7-44EC-A15A-63089CF5B232.jpeg FC3B403D-39D2-4B55-9318-E50CB0D7CC0F.jpeg 11BFE459-21C7-48DC-8B62-D1804377F651.jpeg 4F03F09C-F775-4F1E-953B-DC6285943B02.jpeg 1F86FE06-817F-4FE4-A20F-FF89D81094F4.jpeg E4BE5DB4-3749-4CE7-9688-1EC13DC89575.jpeg B528C082-5CDC-48FB-9B07-2E110134CB73.jpeg 34DEB2AE-90E5-42EF-9660-0B59462C0B5E.jpeg
Really delighted with the end result so thanks very much for all who chipped in on this thread!
Looks great, glad you're happy with the result. I think the system as a whole sounds great!
'83 MK1 Golf GTI
Nice write up and sme cracking photos there  :thumbs:
