No main headlights
Sorry pal I mean this picture all looks good to go fingers crossed' I've plugged in all cables now so just connect the battery and see where we are ahhhrubjonny said
you mean the ignition switch wiring?
black is ignition live to fusebox and also cluster, red/black is starter cranking live, red is live, black/yellow is x-relief live which is on with ignition and dead while cranking, grey if there is parking lights, live ignition off
for the cluster plug if you check between the red and brown you should see permanent live, black to brown ignition live
The black cable you see is earth your scaring me now?
brown wires are pretty much always earth in a VW loom
rubjonny said
black wires from the ignition switch are ignition live, one straight to fusebox and a trhin one to the clocks.
Before I resoldered the black cable I done a continuity test to earth it was confirmed ' need to double check these now I'm worried
for example if you tested for earth at a wire going off to the headlights you'll see continuity to ground through the bulbs
Just want to double check before I connect the battery' I've manage to solder all bad connections and reused the original spades' I've then heat shrink and wrapped with loom tape
you could unplug the red and blue fusebox plugs to isolate the black wire and try again, but to test for shorts to other wires you would have to do a continuity check between black and every other wire in the same harness
best bet is a visual check of the black wire end to end really
All works great guys even the original problem with the headlights.
Ive a few other things to do now the clocks are out' like the radio switched live' which i shall do tomorrow and the cigar lighter' but will start a new post for that
Thanks ever so much guys' i'm really glad i took the clocks out and repaired those terrible connections.
okmate said
Well Thanks to Brianno and rubjonny the job is complete,
I have a how-to int he archive section on cleanign your cigarette lighter to make it work….
connect a 9v battery to the gray/blue wire on the light and the negative to the brown if it don't light the bulb is bad.
There is a how to change the bulb in cabby-info.com.
Cant seem to find them Brianno123
My Cigarette lighter won't charge my Ipad, Iphone. | Volkswagen Owners Club Forum
Whilst that tells you how to fix a funky working lighter, I have since removed them and used a USB jack in it's place as well Cigar's and Cigarettes are bad for you and you shouldn't be smoking, as my kids were using them for USB Aux thingies… and constantly it wouldn't work for my lighter to ignite my Stoogies. I bought a windproof Butane..
Wait, it is there…… I have the screen snap, please ignore the latest posting edit time it is wrong.
Last edit: by Briano1234
