Electric Windows
If you look at the Truth Table, you will see the 3 relays at the top, and one below. It is that lower relay that controls power to either window.  But it is the IC controller that makes it go up or down via the switch input as the IC makes or breaks the other 3 relays.
It could be that you have a broken relay or a cold solder joint that is the issue or a broken trace…
That control unit was used on later Golfs as in 93 and up and passats, as well as jetta's
On the drive
Myvalver 89 GTi Grey mk2 16v
Ken, thanks for the link. As I said I've been blessed with a cabby that has never failed. That link shows loads of stuff. Which one do I need??????
They all the same part.. just match the wires and plug in.
On the drive
Whooo rahhhh mate. I owe you a Diet Coke.
