Had to sorn my golf
(In Topic #223367)
Its had
Stainless steel manifold
Stainless steel full group n exhaust
Head gasket done
Head skimmed
New head bolts
New gaskets
Powder coated rocker cover with gasket
New plugs
New competition leads
New distributor
New cap
New rotor arm
New coil
New engine wiring
New starter motor
New alternator
New water pump
New hoses
Powder coated radiator cowl
New uprated 250w fan
New thermostat
New weber 32/34dtml carburettor
New flanges
New manual choke
Fully dynod to 106bhp
New ramair filter
New oil every 2k
New fuel filter every 3 months
New cam belt
New v belt
New radiator and temp sensor
Timing checked and set
New omp upper strut bar
New wheel bearings x 4
New stub axles rear
New goodridge stainless steel brake hoses
New hydraulic bonnet struts
New copper break pipes
New front crossed drilled and ventilated discs
New front calipers
New rear drum set including all new fittings
New ebc brake pads and shoes
New front wishbones including all new fittings rubbers and ball joints
New stainless steel braided fuel hoses throughout
New meyle fuel pump
New transmission fluid
New coolant bottle and lid
New coolant
New 9inch mk2 golf brake servo
New meyle 22mm master cylinder
Meticulously looked after and valeted ????
There is loads of little bits ive missed out .new stereo speakers etc
New chrome window winders
New scraper seals all round £80
Even vw chrome dust caps lol.
But you get the general picture ive basically replaced everything that i could for new quality parts .
Guys im no expert but what am i doing wrong here ? I have now put 4k in it in 2 years and simply cannot justify having the head done again. The garage who did it ive used for 25 years. They said if i want i could get the engine and head independently checked and if theve done it wrong they'll fix it for free. Problem is they said it woukd not have done 13k if they would have done the head wrong ?? Guys i need opinions here .my pride and joy is in my garage on sorn .??
Had to sorn my golf
Is there water in the oil…. if so it could be the oil cooler and not the head gasket.
Had to sorn my golf
I guess the gasket has blown by one of the head water feeds and it's getting into the cyinder…
Gutted for you fella, cars can be very annoying sometimes.. As you have put a lot of time and money into, save up and get it fixed, it will be worth it in the long run as the prices of these cars can only go up.
Had to sorn my golf
Had to sorn my golf
Had to sorn my golf
It's a lovely looking Mk1, definitely worth keeping and repairing.
I converted an auto mk2 golf 1.6 to 20vt in 5 weeks for under 2k.
Had to sorn my golf
Had to sorn my golf
A head gasket Failure can be a issue with the head being warped again now, or not. The only turely way to be sure is to have it checked, and that would mean taking it off and running it to a shop of you don't have the means to do it yourself.
I would also check the Cylinder walls after cleaning with magna-see to verify that there aren't any cracks as well as having the head looked at for a passage crack.
I had a 81 Diesel that would blow through head gaskets every 6 months after about 130K. I had ti checked for warpage the first two times and the head wasn't warped at all….
Speed forward about 10 years and with the advent of the interweb I found that I had the loss of bite on the head bolts.
I had to sell the ride, but I regretted it, one owner 330K on engine and tranny….but I found that if I had stopped using new bolts and switched to the ARP racing studs that have a longer bite, and locktite on the studs…I wouldn't of had that issue again as the ARP are re-usable, and that after 500 miles all I had to do was to re-tighten or Check-Torque the head….with but the cost of a new valve cover gasket… but as a side note I got really really good at replacing head gaskets on a Diesel and it usually only took me 3 hours to do it from start to finish…. I did re-check torque on them after about 1000 miles, but alas it would blow again a few months later.
So I would remove the head and have it checked for warpage…. If it isn't warped, then using a straight edge I would verify that your block isn't the issue, then use a ARP stud kit and be done with it. Cleaning up the mess is usually the hardest part.
Had to sorn my golf
In the meantime ive been on the lookout for a little runaround
Got a little honda civic 03 plate been well looked after 76k on the clock £600 no glamour but hopefully it will be reliable???
Deano777 said
Thanks for your reply briano always appreciated. I trusted the engineering shop last time to check the whole head and they did .pressure tested it skimmed it etc ??? I do intend to pull the head off when i get chance and take lots of photos .and put them on here for you guys to give a verdict. Im sorry briano .i dont know what arp bolts are mate ??? Il need all the advice i can get when i do the head mate ..
If its a Honda it should run like a watch… and at £600 it sounds like you have got your head on all right (but not the Golf's head - no pun intended ha ha) So take your time and don't dispare as your cabby
is lovely, and it shouldn't be too hard to fix.
Marcus.
Had to sorn my golf
Had to sorn my golf
Most importantly do it yourself and take your time, you know it's done well then.
