Water pump pulley catching plastic cam belt cover!?!?!
I am unsure whether there is any difference in the pulley for 1.6 or 1.8 engines ??
In the VW parts list TWO pulleys are listed for non PAS/aircon models:
026121031 - 1.6 (EW) (HN)
049121031 - 1.6 (EG,EM,,FR) & 1500 (GH, JB) 1.8 (DX, JJ)
All UK suppliers only sell 026121031 - so is this suitable for the 1.8 DX engine ???
Anyone know if there is any difference between the pulleys?
looking at google images of them both look basically the same, but maybe, possibly the 049 isnt quite as deep?
next step I recon check how the v-blet is lining up with the crank, if theres enough wiggle room space the pulley out so it clears the timing belt. or replace waterpump.
hopefully someone has a spare pump they can measure between pump fitting and block bolt hose so you can compare
I have today taken off the metal top and plastic lower cam belt cover.
Fitting the lower pulley and the water pump pulley they are definitely out of alignment. The water pump pulley is set too far back by a few mm.
I still have the old VW water pump I took off - part number: VW 056 121 013A
If I measure from the mounting hole on the pump to the face of the output flange - the VW original is 2mm longer. However even with this original pump and the original pulley it was still rubbing on the lower plastic cam cover.
I reckon the best option is to replace the lower cam cover and the water pump pulley with the 026121031 pulley. The MEYLE pump is brand new so hope not to have to replace that as well!
I've had a rummage in the shed and found another pulley, this one measures 36mm from top ,to bottom when laid on a flat surface, the one on the car appears to measure 33mm. Unfortunately there doesn't seem to be a part number but I'll give it a clean up tomorrow and if there is one will let you know.
