Engine rebuild
Engine rebuild
Engine rebuild
Sent from my SM-G930F using Tapatalk
Could be you have an air-leak somewhere. If you have any carb cleaner, spray that near each one of the inlet manifold tracts (where it meets the head) in turn, and also on where the injectors go into the manifold.
if the engine starts to run a bit better then it's pulling air in where it shouldn't.
I can't see how the valve lifters would cause any kind of running issue to the extent you have seen.
I have the tranny finger at 0 (crank is then at 0tdc.)
I have the Cam gears dot on the back side even with the valve cover tin.
I have the rotor in the middle of the HASH stamped on the side frame of the DIZ. Yours looks a wee bit to the right of center which could be 6 BTDC. I usually rotate the Intermediate shaft to align the DIZ..
For Hydraulic lifters and tappet noises the are filled with oil, the issue is that they gumm up and make noise at starts..
1. you can remove them and clean them and refill with fresh oil.
2. you can run MMO (marvel Mystery oil) in the oil pan and it tends to clean internals and lessens the tappet noise after about 250-500 miles, that is about 1/2 a pint in to the oil…I do this and SeaFoam prior to a oil change.
SeaFoam Engine Cleaner is another thing I do about 500 miles prior to oil change as it tends to clean things as well.
Bought a car that had a heck of a noise from the tappets at start and 2 or 3 doses of MMO for the first 3 oil changes prior took care of that.
Regional Host NE
to many problems paceman good
call but i do not think we are going
to sort the issue the difference is
when you are hands on you have
a chance but sitting typing you
have not got a chance in hell
Regional Host NE
shims mate
nicci21paul said
has it got hydraulic lifters for sure or
shims mate
Very easy to tell, if you have 5 cam caps mechanical.
If you have 4 cam caps and missing one between the number 3 and 4 cylinder you have Hydraulic.
Engine rebuild
Engine rebuild
You can easily blow them apart with forced air and clean the junk out of them…. Then use fresh oil and reassemble.
Guide: How to clean/service your tappets | VW Vortex - Volkswagen Forum
Not saying they are all bad, some may need a little bit of a cleaning.
Regional Host NE
nicci21paul said
That is a Solid lifter head.
A hydraulic head looks like this.
See the missing cam cover?
I guess the oil light comes on and goes off once started?
It does take a few minutes running above idle speed and reving the engine to quite down the tappets as I found when I took my engine and tappets apart.
I also find when the oil is old/due for oil change my tappets are noisy when started and I can sometimes drive a couple of miles before they quite down.
How old are the HT leads, dissy cap and rotor arm?
Are the injectors pushed all the way home?
The problem is working out if the running problem is ignition or fuel side of things…. It easier and cheaper to replace old HT leads, dissy cap and rotor arm than start messing with the fuel injection system…
Double check all the wires, air pipes, sensors etc are fitted correctly as it's all been pulled apart to remove the head.
Last thing I would do is pull out the injectors and check the spray pattern, measure the amount of fuel from each injector, check the injector seals. I guess you have the later air shroud injectors with the "top hat" on them and an air hose from near the throttle body to the head between cylinders 3 and 4, make sure the top hats are still on the injectors as they can fall off…. (guides on the web and here to testing K-jet fuel injectors)
I'm on my 3rd set of injectors in 300,000 miles as they don't last forever but last resort as they are getting expensive now…
More things to check fuel side is the warm up regular (WUR) as that adjusts the fuel pressure when the engine cold…
Sorry if not that clear on things as just thinking out loud…
FYI… 1984 ish is when VW changed from shims to hydraulic tappets so if original engine and head your is well into hydraulic time.
Bit of info here…
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=chat%2Fmk1-golf-chat_2%2Foil-pump-priming
Regional Host NE
your steps back one simple error sit
back and think things out no one knows
what you have done it is all guess work
figure it out 10 minutes 2 days no body
can tell you what is because they are not
face on with the problem you have two
eyes two hands same as every one else
sort your problem think about it mate
Is the dizzy fully seated as that is what drives the oil pump via the intermediate shaft.
It's very hard to trouble shoot something without seeing it first hand, and you seem to have number of different problems. Personally, I'm not sure what problems you've resolved and which you haven't.
I would sit down with a bit of paper and write down each issue and then what steps you've taken to resolve. Try one thing at a time, you have to be methodical about it, think logically and don't jump from one thing to another. Don't take this as being negative, it's the only way to fault find any system. If necessary go right back to beginning and check again. Timing, electrics, fuel. Make sure each checks out before moving on.
