Gap between tyres & suspension
My rims are catching on the actual adjustment things  that the spinners fit onto
Front or back?
I'm assuming front.
You may have too much camber on the front struts. It's amazing what 1 degree does at the top of the wheel!
You may need a 5mm spacer if the camber is at 0 degrees (which it should be from factory)
Ian
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
Yes front and only on drivers side , so I reckon  your correct the camber is off a bit
