launch contol and flatshifter bam engine mk1 golf
Just to let you know I always disconnect battery when I don't use car if that makes any difference so I have only tried it 3miles yesterday and here's what the dash says strange on number 1 setting different to number 2 setting only thing not connected is vac pipe to manifold if that make any different (could be a possibility that the tuner hasn't enabled flat shifter but it was requested with stage 2 and immobilised
Also aren't you supposed to have the 4 pin mk4 brake switch so both ECU brake pins are active? Cruise control certainly won't work without and I though launch control etc needed them both. You't use a normal brake switch for cruse brake switch pin as it works the opposite way so you need the MK4 4 pin one
When loom returned to me I have fitted back to car there was no feed for brake switch on there the only cable that was left was the gearbox one I've shown you a yellow wire and then a blue wire which were oil pressure wires tpease adaptor and a earth for rocker cover I have 16valve servo etc so I had to install switch for brake lights do you think the Ecu thinks the brakes are on ?
