launch contol and flatshifter bam engine mk1 golf
(In Topic #219779)
Thanks for replying just to get straight in my mind I need a feed from nbr6 of the ribbon but will this go to the plug I have in my loom still for 6 speed box as I've used a ASD 5 speed .Will the wire from 6 go to this plug to allow the ECU to recognise the car is in motions if so would you know which wire to feed in the plug ?.Cheers Nick
for the cluster side the blue ribbon is what you're looking for, labelled SSA. it should be fitted inside a plastic plug housing on the back of the clocks and you got a white p[lug to fit into it with all the MFA wiring inside it for oil temp, outside temp etc.
if you dont have a plug housing for it then what you could do is stuff a wire into the back of the speed sensor instead for the short term, saves trying to find a way to attach to the foil contact, its the middle pin you're after
heres the sender on a set of ce1 mk2 golf/rocco clocks but you get the ideal. undo the 2 little screws and you can hinge open the back of the sender, put your wire into the back of it and close it back up
Is blue /white 54 feeding anything else in the management so I can tag on that or do I go to main plug cut back and piggy back solder the wire there , I have the complete plug other end the ribbon is a Spare ribbon I have for a digifiz I would like to try to fit with out cutting the female plugs if I could get hold of nofear on the forum for the digifiz he has for sale . Cheers Nick (plug looks a bit bogged but I managed to cut the ribbon and heat shrink over the exposed areas )
Sorry to bombard you with questions but I would be having a go at making the flat shifter work at weekend and trying to get a few wires in for a digifiz if I manage to get hold of one. Am l right in thinking I need to get a digital feed from black box that turns the digital feed into analog for my dash at the moment and leave that feed out no my plug because a analog feed will blow the digifiz i bits .Thanks again Nick
for digifiz you need to wire up that 3 pin plug you pictured earlier to the cluster. also FYI the VSS and speed signal input is to the same pin on the clocks, the gearbox sender outputs the same signal as the sender on the back of the mk1/2 clocks
for speedometer if you have an 02A/J box you plug the connector above straight in and go. for analogue speedometer simple unscrew the 3 pin plug assembly from the back of the mechanical sender and fit a 1.0-1.3 mk1 speedometer cable to it.
if its 020 then you remove the ele3ctronic sender entirely and fit a mk1 1.5-1.8 cable with a red gear (usually, check box code first) and gear retaining circlip
if its an 02M then sender is purely electronic so need an adaptor for it
I will have a go at weekend and let you know how I get on . Thanks for the help on the digifiz in regards of speedo that you actually answered another question I was going to ask but after reading my post didn't actually mention that I was referring to wiring for the Rev counter need turning back to digital instead of analog .Much Appropriated Nick (there is a few questions I would like to ask but not going to waste your time until I have a digifiz)
you only need the adaptor for MK1/2 clocks, or if you're crafty you can open the clocks and bypass all the signal processing circuit and they;'ll run off the mk3/4 ecu signal as well
Just saving my Christmas cash for a digifiz and new facia front for it if I'm lucky enough to get one at right price that works .This may be a long shot but I have emailed vw at Germany to try and authenticate my mk1 golf GTI as the year and manufacturing numbers has it coming in as a campaign but what I think the car is possibly a car that a person in the armed forces has bought back from Germany and is a Pirelli edition as a lot of school pals that was in the army were saving tax on BMW etc and then driving home .(were the best place to find this out ) Thanks Nick
VW can check the codes for you though if the service book is missing
https://clubgti.com/forums/index.php?threads/applying-for-your-volkswagens-birth-certificate-link.211662/
All I have is vin numbers and numbers in scuttle and log book .Never mind Im happy with car what ever it is strange one as it a tin top and Ive read that some pirelli cars had no sunroof if requested on a Y plate .
Had a bash at getting flat shifter to work today soldered blue /white location pin 54 to rear location 6 SSA on my white plug there was no terminal or wire going into that location so soldered a savaged terminal and slotted that in to position but no joy on flat shifter . Found pin diagram I think for bam ECU and shows 54 pin blue/white indicator/buzzer generator is this correct
