Nearly in tears
Gutted
I wasent sure if it was a fuel line or a brake line just took a picture of it as it looked heavily corroded when the ups delivery comes today ive been advised to refuse it when they have it back they will send me a non cat version which is apparently £20 cheaper ?? Do you have and links to a full system in stainless mate
AVS Car Parts
VW filter
Genuine 056115561G Oil Filter | AVS Car Parts
I use this oil. Use the discount code to get the best deal, they do change alot…..
https://www.eurocarparts.com/ecp/p/car-parts/engine-parts/engine-parts1/engine-oils/?521776011&1&cc5_245
This MANN filter.
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-parts/regular-service/car-service-parts/oil-filter/?501770059&1&df2e88f773d5c865f404b9dd795cf6fb0b433883&000231
Don't forget a new sump plug washer.
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-parts/engine-parts1/engine-parts/sump-pans-and-sump-plug/?333771291&1&47c8751ced189bff5450784e05f1acd1b6276fd2&000567
If it's low then it's either a really clean burn hence your engine is really , really good or there's too much air on the mixture so very little fuel is being used in the burn.
This means it could be running lean. If it lean then it'll also be running hotter than it should do.
This can lead to scoring of the chambers as the pistons heat up too much and expand rubbing the rings against the side walls.
If it's really lean then there may also be running problems and staling.
Might be worth seeing if someone can tune it for you. It'll need tuning after the new manifold is on anyway as you're effectively allowing it to breathe easier and you'll need a bit more fuel to compensate.
Ian
The Flexure is to prevent the torque of the engine, from cracking the header pipes.
The new Headers pipes are 4 times the surface area of the old and they run closer to the starters heat shield, closer to the CV, and the steering rack.
You can make heat shields out of sheet aluminum to dissipate the heat. Or you can wrap them with the heat shielding tape.
Or not.
If you haven't installed the heat soak relay on your starter (you do have an Automatic), then I would strongly urge you to do it now.
It is all up to you and what you want to spend now, or spend later. As my Grandfather used to say… Es geht mir nicht, aber du.
The heat soak relay was due to the issue with after driving the Automatic cars for extended periods as in Hours at a time (the US is really really big). You stop for Gas and you got to start the car and it doesn't click, spin or start….. But if you waited about an hour, it would start.
If you look for the Starter Solenoid Wire that goes over the transmission (red/white) you will find a yellow jumper block, Car in Neutral or Park, key in the run position, Jumper from 12V+ to that yellow jumper and your car will start. incase you get stranded….in the future.
http://www.cabby-info.com/Files/InstallingHot-startRelay.pdf
Might as well do it right now as once on the car it will be near impossible to wrap.
I've used a mat like this (you can buy them in screwfix etc……) Then used a couple of the stainless steel ties from the exhaust wrap to hold it in place.
https://www.ebay.co.uk/itm/Heat-Resistant-Mat-Soldering-Brazing-Plumbers-Woven-Glass-Fabric-300mm-x-250mm/192329893370?epid=4006939515&hash=item2cc7c145fa:g:GdoAAOSwevdZ9JHI
