CABBY FUEL PUMP making noise
External fuel pump under tank making noise
Golf 1993 clipper
Audi A3 S line Quattro
125,000 miles is nothing for the main pump. Mine went at 240,000 miles.
The main problem with removing the main pump is it lives underneath the car and all the connections are exposed to the elements, you need to either drain the fuel tank or run it low and clamp the rubber fuel hose to stop it emptying petrol on to you.
It took me 2 days to change mine as there was a lot of soaking in Plusgas as you can't use any heat to undo the rusty connection.
I follow the old saying "If it ain't broke don't fix it."
Dont forget with the lift pump you will need to change the little bit of rubber hose between the pump and sender as they rot and fall apart with all the ethanol they put in petrol now a days, when fitted you need to make sure the lift pump is the same height as before as if it to high in the fuel you can run out of petrol before the tank is empty (never a good idea with these old cars and fuel tanks) or to low and it can pick up the petro very well. The Haynes manual does show the measure s You will also need 2 or possible 4 fuel pipe jubilee clips as VW fitted use once pipe clips.
How I change my in-tank pump is
1984.5-1993 mk1 How to change your in-tank fuel pump | Volkswagen Owners Club Forum
I've already printed off your how to guide lol
Golf 1993 clipper
Would be worth checking the condition of the filler neck as they have a tendency to rot out as mine had done filling the tank with rust and debris which ultimately spelt the end for the fuel pump. Just worth checking before you fit a new pump as they’re quite expensive. Good luck
Sent from my iPhone using Tapatalk Pro
1992 1.8 8 valve Convertible GTI
2008 E93 335i N54 Twin Turbo
3 Kids
Suzuki LT50 Quad
( and the Mrs )
3 Kids
Suzuki LT50 Quad
( and the Mrs )
Golf 1993 clipper
Any news? Did pumps swap work?scotty b said
Ok guys thanks for all your info I think I'm going to replace both tomorrow anyway as due to a very good mate I've only paid £60 for bosch pump and £20 For the lift pump as he works for car part company lucky me.
hopefully it may fix my issue
On the drive
Myvalver 89 GTi Grey mk2 16v
Golf 1993 clipper
