Jom Bonnet lifters fitting help!
Cheers buddy..👍
1990 Golf GTI cabrio 1.8i.  DX Engine
I await the results with baited breath  :lol:
Did you not see the same ones at £8 though?  :P
Personally I'm painting mine to match the bay……..
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
DOH ! I saw some £11 ones but they were 550mm long and then I gave up looking
  1992 1.8 8 valve Convertible GTI
  2008 E93 335i N54 Twin Turbo
  3 Kids
  Suzuki LT50 Quad
S,up dude , I received my bonnet lifters today and they look like they'll fit BUT !! Have you lined up yours ie angle from the wing to the hinge, I'll try and explain what I mean. If I was to bolt the ram to the top of the wing I wouldn't be able to lift them to the angle required to reach the bolt hole on the hinge. The ram will not articulate on the ball enough as they seem to be designed to work at 90 degrees i.e. Side on so I think I'm going to take a die grinder to the end and scallop an little bit to let them move to the correct angle, simples
  3 Kids
  Suzuki LT50 Quad
Same with the JOM ones I had. The movement on the ball will not let the angle be made to open the bonnet correctly or fully as it's making the cup almost pop off the ball.
Also the wing bolt hole if you were to use it would need drilling out a bit as the threads on the ball joints supplied were metric.👎
Don't worry no biggie, give me a few days
  3 Kids
  Suzuki LT50 Quad
See what you mean. As I haven't bolted them down tight yet (so much inderseal to remove under the wing bit) they are moving in the wing hole and taking up that bit of play.
Good catch!  :thumbs:
Cornish Host.
1980 VW Derby
Clive the Cabby
Ujum the Invisible
Mynx the  Tintop
That's why mine are fitted to the bolt hole nearest the windscreen - mine are Bonrath ones. The bolt in the wing is also the nut and bolt type to make sure that is it securely fastened, you can get swivel ends that are the same thread as the wing bolts, but I didn't fancy the gas pressure in just the threads.
Cheers,
Ade
On the subject of these. I have seen numerous people asking for English instructions for the JOM ones. Found this thread for any one that wants to try fitting them.
Kit Contents:
1. Hood-lift (2x)
2. rectangular joint + security clip (4x)
3. Ball pin M6 x 20mm (4x)
4. Washer large M6 (2x)
5. Washer M6 small (2x)
6. nut M6 (2x)
Tools Required:
-10mm Wrench (2x)
-Boring machine [drill?] + 4mm and 6mm drill [bit?]
Assembly:
1. Remove the front M6 bolts from the left hinge (A)
2. Mount at this point the ball stud M6 x 20mm (do not forget the M6 ​​washer!)
3. For mounting on the fender a 6mm hole to be drilled at 335mm from the hood hinge arm (B). Warning: the hole is to be drilled 20mm from the side (C).
4. On this point an anti-rust treatment and mount the ball pins (with the large washer on the upper side and the M6 ​​nut with small washer on the bottom) on the fender. (For some models, it may be necessary to remove the inner fender to mount the mother can [note: not sure "mother can" is a thing].)
5. Screw the joint on the HoodLift and remove the retaining clip.
6. Assemble the Hood Lift (with the cylinder upwards !!) on the ball pin (this should be well mounted).
7. Assemble the clip back into the joints. These provide a good, lasting impact.
8. Repeat the same procedure for the right side.
