1.8 8v Gti running issues
1.8 Gti stuttering as if not getting enough fuel or missing
ConvictGTI-No.1983EW said
Ryan,
Make sure the warm up regulator relay buzzes, which is located above the fuse box, as well as the fuel pump when you first attempt to crank the engine .
There should be two buzzing sounds when you turn the key-the first one will come from the rear of the car (fuel pump) priming and the second will come from under the dash where the WUR relay is located along the top of the fuse box.
If there's no buzzing coming from under the dash near the fuse box check the WU Relay along the top row of relays on the fuse box.
I had a hell of a time with my 1993 1.8 JH engine cabrio, when it would intermittently run perfectly then next start refuse to fire or start then rev, splutter and stall.
I pulled the WUR apart and cleaned it, had the cold start valve - ( 5th injector) cleaned, pulled the tank pumps out etc etc….
Many articles have listed all sorts of remedies but it was by sure luck on the USA Cabby Co website - Trouble Shooting, one person mentioned the warm up regulator relay.
To cut a long story short, the relay was working its way loose from the contacts/wiring on the fuse box.
This happened if I nudged the gutter when parking front in or travelled on gravel/corrugated roads.
To test the relay simply listen or touch the outside of relay whilst cranking the engine when its cold. It will vibrate/buzz if its working. If it doesn't press it in or wriggle it and try to start the car again.
I didn't know much about K-jetronic fuel injection but I do now after that experience!
I bought a refurb kit for my WUR, and having stripped it, it appeared in pretty good condition. I replaced everything anyway and fitted it back to the engine. NO DIFFERENCE!
I'll be fitting the WUR I was kindly sent this week to see if that changes anything, but I don't hold any hope at this point.
What I did for my own curiosity was start the engine from cold, and remove the electrical connection from the WUR to see if it changed anything. Again, no change, so I attached and removed it several times but there was no difference in the way the engine ran (which was badly).
My next step after trying the other WUR is to replace or at least test the relays under the dash.
DOES ANYONE KNOW WHAT NUMBER RELAY IS SPECIFIC TO THE WUR?
I'll be honest I haven't read through all of this thread but my advice for what it's worth is invest in a fuel pressure gauge, without one you're just guessing, if it is the WUR or control pressure regulator it will show up immediately. If you do get one be careful though, cover the battery well and have a decent extinguisher.
I have a heavy length of electrical flex long enough to reach from the relay board to the front of the car 1mm I think it is, one end is soldered to the large contacts of an old fuel pump relay and the other has a switch attached to operate the pump remotely, much easier than fiddling around at the relay board.
Last edit: by cedar
I went through similar pain on my Rivage. Similar spluttering
- replaced Fuel pumps
- timing checked over and over again
- oil pump
- spark plugs and leads replaced
- tried another metering head (no good)
- WUR seemed to check out ok.
In the end I pulled all 4 injectors out and made a little rig up using some empty clear beer bottles, bridged the fuel relay and saw that 3 out of 4 injectors were clogged , 2 were just a dribble.
I replaced all 4 with new ones (£120 from car parts for less)and then I had to sort out fuelling as the previous owner had increased fuelling to compensate, once this was adjusted its been running like a dream since.
bottles below in link
http://i44.photobucket.com/albums/f16/b4dxx/Cars/Green%20Rivage/4BD0E9EE-FAE7-4A03-B6BE-4D37139C1D1A_zpsnxhzthi5.mp4
Hope that helps
Alps
Last edit: by Alps
Alps 1992 Rivage Green, 1991 Rivage Blue (SOLD), 1986 GTI convertible White (SOLD)
Alps said
Hi Ryan
- oil pump
http://s44.photobucket.com/user/b4dxx/media/Cars/Green%20Rivage/4BD0E9EE-FAE7-4A03-B6BE-4D37139C1D1A_zpsnxhzthi5.mp4.html that helps
Alps
Link not working, copy and paste the IMG code into your post.
Re:
Sent from my HTC 10 using Tapatalk
My old injectors would seem to flood the car when starting from cold so I would run without the 5th injector plugged in and it would start a bit better.
Hesitation on accelerating.
You can pull them out and check the spray pattern and see if the leak before fitting new ones as they have seem to gone up in price over the years.
have you had the base idle and co checked yet? your symptoms sound similar to what I had on my digifant mk2 when it was set way to lean
I'll look into testing if not replacing my injectors in the meantime then. And to answer a previous post I don't have a brown Haynes I have the red.
Re:
On another note, I have two injectors that are not working correctly. The spray pattern is not a cone shape, it looks like an old man having a pee. So I'm looking for a company local to me to price up refurbishing them all to see if it's worth doing that or buying new.
I also have some head and injector issues which will take some explaining if anyone's game?
Re: 1.8 8v Gti running issues
Sorry, I forgot to say it's the white relay that clicks
He is also on ebay as well, that's how I found him.
If there was a fault with the relay the car would not start.
Have you tried unplugging the blue electrical plug on the 5th injector and starting the car? If the injectors are leaking fuel when the car is switched off it floods the engine when you start it and the 5th injector sprays more fuel in. I ran for about a year without the 5th injector as I had leakey injectors.
I have an update on the injector issues. I've taken then to reputable injector specialist in Swansea (before I saw your suggestions guys), one has been cleaned and is now working 100% in testing, though not in the car yet as I haven't had them back.
The guy is also able to get the original Bosch injectors for a pretty good price too. The second injector that wasn't working didn't clean up so well, so I'm having a new one. The tester told me that they were both full of junk (probably from the rust in the tank from the filler neck which I changed a long time ago). With that in mind, I'm taking the other two to be cleaned and tested next month.
Thanks again for all your help guys, your knowledge is far deeper than mine.
