my white 83 gti
I think you can buy floor repair sections. Otherwise, find someone with a shell being cut up. That's what I did for a section of mine.
Have a nose through my resto thread if you need any reference pics for similar areas.
There's a lot of pages of rubbish to get through but hopefully something useful!! lol
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=misc&id=projects%2Fyour-mk1-golfs_2%2Fat-last-hairys-resto&start=380
1983 mk1 gti white bought as a daily now in pieces..
i have the drivers side rear beam mount section all prepped ready for the panel to go on but the repair panel is oversized it sits as if it is supposed to be placed over the top of the original section it going to take a lot of cutting and bashing to make it small enough to be placed into the bit i have cut out as a but welded piece rather than overlap.
the rear panel is off so i can get to the rear of the boot floor that needs attention and the bottom corners of the rear arches. everything is ready to go other than i have no rear inner arch repair panels and nobody has them in stock!
the outer arches look a very good fit when offering up against the car. as does the rear panel.
so i cut back until i had solid metal and replaced it with new.
i then put my rear beam mount box section repair panels in. when you remove these you find the piece that comes down and sits against the back of it is totally rotten so these also got cut out and replaced whilst i was at it. the welding underneath the car went quite well compared to the boot floor attempt.
offering up the repair panel, holes drilled to plug weld
plug welded and then i welded all the way around the outside and protected it all.
little bit better than how it was!
so i moved onto the passenger side rear beam section and done exactly the same. the rot here was nowhere near as bad but the cutting out and replacement was just as much hassle as the drivers side. access is the problem. you have to remove a section of the inner and outer sill to get to the flat back place the mount sits against.
underneath done i set about removing my inner and outer arches for replacement, the drivers side had fibreglass covering a rotten hole and the passenger side had no inner arch lip at all they had been cut off previously and just the outer replaced ( they had just tacked it into place every few inches and left the gap to eat some filler.. ok lots of filler) this is what i found when i took back the paint and filler
. the inners edge had been left raw and water just sat between the 2. baffles me why anyone would go through that effort and then not seal it with something. but hey ho.
only picture i have of my inner arch work. welded and then ground down.
both sides done and then the part i was most worried about outer arches. with this all being very new to me and my first ever attempt at ANY car work at all i had read lots about warping and all sorts of potential issues and the fact the car had cost me a lot of money to buy and i had already chopped it up i was determined to get this right. tbh it was nowhere near as bad as i thought it would be. i mean it might be total dog sh … and fall off in 6 months but it looks ok to me? compared to everything else i found online while doing research it doesn't look any different. i was getting good penetration and no blow outs, everything lined up as i wanted it to after cutting the old ones out.
i tacked the outer arch on in a couple of places and then slowly added tacks at various places around the arch pushing and pulling slightly so everything was flush and uniform.
and then started to grind down the welds
this is when it all went wrong for me i got something in my eye whilst wearing goggles. plus i already where glasses as well. basically spent a day and night with irritating eye it went for a day then came back and then went again until the third day i woke up and had cloudy eye with non responsive pupil i knew i had to go to hospital as it was unbearable at this point. basically got sent to a second hospital where an eye specialist numbed it and removed a metal splinter from the centre of my eye that had rusted and left some damage which he says will go with time. until then it still feels like i have shrapnel in there. so i am sitting hear with a gammy eye not being able to do much at all. i have just bought (put a deposit on) a full bam engine from an S3 with turbo,loom,ecu and so on and also bought the mounts and downpipe for it. i was going to use a full donor mk4 i bought with an AUQ but i am going to sell that as a complete car its too good to scrap the car just for the sake of getting the auq engine. i prefer the bam style inlet and pipework anyway.
for anyone who has done inner and outer arch work before what did you cover the surface of your inner arch with (over the welds) before fitting your outer arch? my rear panel is near enough ready to go on i am ust drilling the holes into the edges so it can be plug and spot welded in place. i plan to replace the rear of the boot floor once the rear panel is in situ. then i just have to finish grinding everything down protect it all from the elements as much as possible, seam seal and under-seal what i can until i can get it into a paint shop for a respray.
I will have to do the same to mine at some point, I just don't know if I've got the balls to take it on myself! I'm certainly not confident enough to tackle a wheel-arch but it looks like you've got the hang of it.
Keep up the good work, I look forward to seeing some more updates soon!
can anyone give some advice on sanding down the filler on the curve of the arch? i have but welded my new panels on in the dip of the arch. im worried about how i will get it presentable is there a special curve sanding block for this kind of area. many thanks
When I did my first arch repair I was luck I didn't have to cut too much off and welded in the middle of the arch, as thought sanding the radius or grinding down the welds may be a problem.
If there's not too much shaping to be done, then I would have thought your finger would be enough to sand to the right profile.
Otherwise you could try lead loading it, and make up a wooden paddle of the right shape.
i am going to underseal the rear end everywhere i can before re fitting my petrol tank rear beam..
underneath showing penetration and the Chanel/pattern before i bashed it up and welded it shut.
and my new lip overview
Very very good effort so far, impressive stuff. Especially doing the work outside in this country, in November
If I was wearing a hat I'd take it off
Last edit: by dan-j-w
dan-j-w said
the good news i move house in a couple of weeks from essex to dorset and the new place has a garage! so i really cant wait to get it out of the elements and be able to work on it without looking over my shoulder constantly
looking good so far, must be a pain doing it outside, a garage can only help things !!
where in dorset are you moving to???? i am down that way, very nice down here !
