my white 83 gti
1983 mk1 gti white bought as a daily now in pieces..
Regards Volkswarren
I know how you feel, I was going through a similar thing in the spring with mine. I wasn't planning a respray but I thought I had a solid shell which needed a bit of cosmetic work which could be done as and when but a few pokes and prods and I had holes like yours!
Keep your chin up mate and don't let it beat you! You don't have to replace the whole tub, I did some temporary repairs on mine with a view that in a few years time when the funds permit I can get it done properly! It needs the rear arch, inner arch, sill and axle mount doing properly but I patched it up sufficiently for a few years!
But can say my cabrio is best shell I ever seen
It's never had welder or grinder on it any were
I only know this because I stripped to bare shell to paint it back to red 10yrs ago even to this date when goes for mot they don't check the car as its like brand new from front to back
i cant quite work out whats what here. when looking at inner and outer arch repair panels neither of them cover that part? it looks to high up to be part of the sill piece.
i know the bit at the bottom and the bit at the back around the hole for the hoses is part of the arch tub. but theres a join line running down when you look towards the front of the car..
I changed the arch tub on mine after trying to patch it and giving up. To be honest, the arch tub repair wasn't too difficult at all. If you can stump up the money for the panel, then it's probably going to be quicker and easy than patching it.
I had exactly the same on mine. I think it was the very first bit of welding I tackled. Should be some pics of how I did it on my build thread.
My Build Thread
https://www.vwheritage.com/shop/golf-mk1/BBW803422F/rear-wheel-arch-tub-right-mk1-golf/?crumbStartPage=1&crumbStartRow=1
They're also about half the price I thought they were!
Whichever method you choose you'll be stripping fuel system out, so I'd say go for this option all day long. Higher material cost than patching-up but will be much quicker and easier I reckon
i plan to start with these, removing them looks to be the trickiest part. once they are off i can tackle the rear of the sill.. the front of the sills look good but once your fully underneath the car and looking outwards the back flat area of the sill nearest the rear arch ( where the brake line bracket is on the chassis) has rotted through and its hidden behind the box section piece. hopefully its not to tricky to cut out and replace but once thats on the new box section/beam mount piece can go on over the studs. and then the inner and outer arch pieces.. totally the wrong time of year to be doing this outside but i am doing my best to keep any damp out. nothing is being left bare metal for any time at all.
i cut out the rusted areas from the back of the drivers side wheel tub last night and plan to just make those pieces up myself rather than replace the whole tub as the rest is solid. so so much more work than i expected but i am sure nearly every classic car owner has been through it.
nothing like diving in the deep end my previous mechanical experience is NILL i have bought all my tools and stuff over the last 6 months since owning the car..
dan-j-w said
absolutely gutting to think 6 weeks ago i was flying about in the mk1 happy as larry looking forward to a respray and a 20v conversion for winter now i have a chopped up shell sat on axle stands with more and more being cut out everyday.
Welcome to the wonderful world of MK1 Golf ownership!
They like to keep you on your toes!
My Build Thread
its getting harder and harder to find a solid one outside never mind underneath too.
1979 Series 1 MK1 Golf 3 door Tintop
1997 Mk3 Golf VRT 400BHP Track Car
1997 MK3 Golf Estate 1.8T 280BHP Sleeper
Boring Golf TDI Daily
theres a thin box section sat over the top of the re enforced plate that holds the 2 threaded studs.
that re enforced plate is welded to a side wall piece that drops down from the floor. and behind that side wall it meets the inner sill and then obviously the outer sill sweeps underneath and meets at the same place.
at first glance all i could see was a rotten mess of metal lips coming from all angles! its all cut out on the drivers side now and repair panels have been ordered.
i am rushing home from work at 5pm uncovering the car and getting 1-2 hours to get a bit done each day. im confident in doing these repairs underneath, the rear panel and the 2 patches in the tub but not so sure i want to tackle the outer arches myself. i understand its just a lot of small tack welds done slowly and back and forth but i wouldn't know how to go about getting them to fit correctly/ where to cut the old ones out and how to then cut the new ones in. as i need to do the inner arch lip as well.
and then laying on my back under the car looking up the area next to the rear beam mount is what made me worry the most, but as i said i soon realised its just a fairly simple box section sat over the top of a thick metal u shaped plate that holds the studs for the mount.
and then this is a phone picture with flash on in the dark of the area i wanted to get to its not clear but it has rusted through along the bottom edge where the inner and outer arch go against it. pics are before i cut away the box section around the studs. i will update with clear pics at the weekend.
i am waiting on delivery of all my panels.
i have inner and outer rear arches, rear beam mount box sections and a rear panel for the moment.
today i am going to remove the rest of the engine bay and the dash so i can clean up the front footwells make sure there is no rust issues and it needs to be out for the 20v install after paint anyway.
the only thing i cant quite figure out how to do is the rear of the boot floor that meets the rear panel. the little gully/dip that runs along the rear has rusted through in about 4 places along the length of it. once my rear panel is off i will have easy access to this but not sure how to attack it. theres to many small areas to cut out individually but i dont like the look of it when its been chopped out as a whole and replaced with a single piece of flat metal. heres one i found on google i need to do this but try and keep the shape of the original floor as much as possible!
