Tappety top end
had a similar tappet noise after I swapped an engine, changed to fully synthetic oil and it stopped. might be worth a go before changing the head
Yeah might look into the oil as well
mk1 silver campaign totally standard lowered on coilovers magic tree vanilla
Just had a full outer body restore
Technician used 15/30 oil so not sure which way to go. I've always used 20/40 and it is the same head
worth a go but thinking back mine was tappety all the time from cold, and it was a 16v engine.
This is what a VW garage would use…….
AVS Car Parts
Assuming its a solid tappet head the first thing that needs checking are the gaps! If its hydraulic lifter then check the oil pressure of the new bottom end. :thumbs:
