Auto wont start!
Knowing that you need about 18 inches of Extensions, and a Wobble end on one. Tape the socket to the extension.
Remove the Heat shield bolts on the back first.
Remove the Heat shield 13mm bolt next.
Then the power from the battery,
Power lead from the starter, and solenoid
Remove the other two bolts.
Going back you sort of start the bottom bolt, then put the back brace on to hold it while you get the other two started and installed …. The top one I usually Use masking tape to hold it where it goes, or Tape the Bolt to the Socket.
here is how I do it.
Automatic Starter Removal/Install | Volkswagen Owners Club Forum
mine conked out waiting for a ferry at Calais having enjoyed a great weekend in Amsterdam (how could anyone not enjoy Amsterdam?!. and embarrassingly had to be towed onto the boat. I was expecting to have to be towed off again but it started fine. it then behaved itself for several weeks until it happened again. It was at that point I noticed that the immobiliser may be at fault and wiggling the wires at the back of the immobiliser socket worked but then I ditched it altogether. Touch wood, its been ok ever since…
