20v turbo mk1
6 speed 20v turbo
I think I've got a problem please take a look at the picture up of the shaft angle see what you think of it if its no good (I don't think it is) then I'll be making up another 2 mounts to set it in the right place please let me know that you all think your opinions are welcomed 👍🏻
Last edit: by Yappy
Good job i went out and took a picture lol, first shakedown loose bolt!!!!
That looks to be a little less angle than mine sh1t Hahahaha
I am
Hoping to get it finished up for early next year just gotta get a sill panel and a passenger floor panel and rear valance then the build can really start to take shape but before all of that I think I need to move the engine and box back about an inch 😩
it's quite difficult to make out the angle because I can't get the camera in there with everything built up…….
tried one from under the front……..
i reckon it's probably about a 10-12 degree angle.
The Red Rocket! My Mk1 Tdi Build.....
My VAG family:
1982 Mk1, PD130 Tdi, 6 speed, ongoing project, to be my daily driver (one day)!
1983 Mk1, 1.8 Gti, stripped out, ongoing project, track car only.
1990 Mk1 Cabrio, 1.8 8v Turbo, G60 ECU, long term project (17 years so far)!
2008 T5 LWB, 1.9 Tdi, to be converted to camper when I've finished using it as a van!
1999 Audi A4 Avant Quattro, 2.5 Tdi, currently off the road, more work required.
2010 Tiguan R-Line, daily driver.
My VAG family:
Mine doesn't look to different to yours you know
Does yours drive ok
How many miles has it done since you've built it?
Here's mine what I've done with the long drivers side shaft
Yappy said
Cheers mate
Does yours drive ok
I didn't actually do the conversion but have done about 5k miles since I've had it. It needs a bit of improvement in the design but no issues with the driveshafts. It torque-steers ALOT!
My main concern is with the vertical angle of the driveshaft when I get the car on air; will the CV joint stay together?………
My VAG family:
My VAG family:
Mine are pretty severe but I think it should be fine I will try mine on my ramp when I get chance and jack it up so I get full on suspension sag and take some pics of it when it's up and in the air I think it will be fine
Mine are at about 20degree angle sloping up and back about 10-15degrees of i could get the engine back an inch then I would be more happy with it
But I may just try it as is then see how things go from there plus should give it a good test being around 350bhp
It's not going as quick as I wanted but will get there eventually haha
