exhaust banging under car
rubjonny said
is the isv vibrating away with ignition on?
What's a isv, pictures will help
It's all shits and giggles until someone giggles and shits
if you feel up underneath you can touch it though. so switch on ign and feel to see if its vibrating
then give it a good spray of silicone lube to make sure its all smooth then see how you go.
my abf was really picky about isv though i tried 3 before i found one it found to be acceptable
if you have vagcom theres a reset proicedure you can do to match throttle and isv, check my sig for the various abf info (do ctrl f and type 'abf')
rubjonny said
inlet air temp sensor, you want it as close to the inlet air as you can manage, preferably inside the air filter but strapped to the side will be ok
