My $700 88 Cabby
(In Topic #191532)
Bought this 88 Cabriolet as a B Day gift to Myself back in March…. 1st time VW owner When I bought it Did the motor mounts…Installed new front speakers…. still had the original 1988 magnets in the doors(cones had disinegrated) and of course new wires had to be run as the old ones were broken in a few places… So a 1/2 hour job turned into a 2 hour job Also swapped in some new plug leads… runs much better (the PO had the wrong ones on it) Bought some Centerline wheels with almost new tires for $200…. Sold the Snowflakes and shot tires for $150… Polished them up (2hrs work for all 4) Sorted a rough running cold start issue… A disconnected vacuum line running into the drivers fender… Reconnected and runs way smoother… Also cleaned out the rain tray and "stitched" the plastic cover back into one piece… Musta been 1/2 a pound of cr
P
in each side… used a stick to clear the rubber drains as they were packed solid… Added a "billet" gas cap too Added a fairly rare KAMEI "Hood Scoop" …. Found it on eBay.de….. Need to find a colour match paint… New horn button…. the old ford one just didn't do Did the front rotors and pads as the old ones we're shot (rotors we're heat cracked and OE) Replaced the antenna with a stock one… Much better reception Changed out the stock crappy dash lights for blue LED's Just finished a road trip accross Canada…. Vancouver to Toronto…. 4602 km's…. in less than 60hrs…. And thats after losing 5th gear about 1/2 way Whatcha think??
Wow not bad for what you paid. And you got quite a bit done already. I also like the LED's inside.
What did you use to polish the wheels??
MK1CRAZY YAHOOOOO!!!!!
Thanx….
Used "Mothers Billet polish" and the "Mothers Cone"…. Worked a treat
Looking for coil overs next
Graffitti Lane looks good
Drove it 4600 + km across Canada… Was insanely cold… Heater gave out, so it was down as low as -35 IN THE CAR…
Last edit: by MrPapageorgio
That's c.c.c.cc…cccc.cold!!!
Wow fair play that must have been one cold cabby !
1.8T CABBY
1.8T CABBY
And we complain about our weather!!!
Ok…. So I figured out that My 88 in an "AZUR" Anyone know where You can get the graphic's for the rear 1/4 panels??
http://www.cabby-info.com/azur.htm
Bought a Scirocco lower "K" bar.... need it to stop raining now
Love the steering wheel
Matt
Matt
