Strut top replacement....
(In Topic #186159)
Hi, I've been informed that the gap at top (See photo) means that my top mounts are done?
the car is very crashy at the front end with a knocking noise going over bumps while turning. I just thought it was the rubbish coil overs. Anyway, going to replace the top mounts. is the kit below suitable to use with coil overs? Does it matter if you have a standard setup or coilovers, to which top mounts you buy?
appreciate any help, thanks
Stu
Someone might tell you that they are still fine as I'm no mechanic but they look interesting :-)
You are better with Febi top mounts IMO and u can get them and all the bump stops and covers from funk-star on his classic-vw site on the homepage.
also get 4 new nuts, spring washers and washers from his site when your at it :-)
http://www.classic-vw.co.uk/mk1-golf-suspension-top-mount-febi-3882-p.asp
http://www.classic-vw.co.uk/mk1-golf-suspension-dust-shield-4183-p.asp
http://www.classic-vw.co.uk/mk1-golf-suspension-bump-stop-4184-p.asp
http://www.classic-vw.co.uk/mk1-golf-top-mount-spacer-4186-p.asp
http://www.classic-vw.co.uk/mk1-golf-top-mount-spring-washer-4188-p.asp
2 of each except 4 spring washers and message him for 4 normal washers and 4 nuts.
If your running coil overs then you have no use for bump stops. Also if you buy budget top mounts you will be replacing in 6 months as the coil overs will kill them. But decent 1st time.
*buy decent 1st time rather
I never even noticed Stu said coilies
He even told me at the show last Sunday
Hey thanks for the info. Funk star, can you give me a cost for the list above? Plus the extra washers/nuts Chris mentioned above?
Chris put links to the shop mate. Click the blue writing :-)
Stu around £40 :-) plus delivery !!
Chris, did you do this job yourself? If so how did you go about it?
Pop through and I will give u a hand when u do them :-)
Chris is an expert now
Only trying to help
funk-star
I know. And I'm saying that your a expert now.
Your suspension has been on and off more than most
I will take any help going, chris will let you know when I get the parts.
Ok Stu, I've not done coilies but when I get stuck I will text
funk-star
Did I mention I'm changing to a premium rate number
Great shout Chris - I'm missing some of those parts too.
Haha - need to email then.
Couldn't find any of the items on location 1 or 19 on your site Mark so my order was below the min £9.99
Looking for 2 of item 1 and 2 of 19. And 4 of each of items on location 13, 14 and 15. I'll email you too.
Regards Iain
Regards Iain
Iain
I think its today the Mark is away on his hols, I thin k hes back to work on the 9th June.
Remind me then and I will help u sort the parts out.
Chris
No I'm not away until Friday.
Just needed to set a early deadline for orders. :-)
