Rev counter drops to zero and clock display goes off when I switch on my headlights.....
86 gti cabby
Last edit: by mark1gls
Or is there a way to test without re-connecting battery?
Is it documented anywhere what I should measure each pin for?
I’ve run an Earth to the frame at the back behind the cluster, as per Brian’s suggestion. There is SO much already going on around my fuse box, I’ll be happy for any cable I don’t need to put down there
if it fixes it, then great, you have a break in the brown wire somewhere. if not, its the cluster. or maybe the pin is loose in the plug. if you open the flap on the rear of the plug all the pins just pull out, clean them up and tweak till they make nice contact with the copper pads on the clocks.
watch out for the red wire, its permanent live so dont let it short anywhere else you'll pop the fuse. you could just remove the fuse though to kill power to it while you're working
when you make this connection just be aware that the MFA stalk also earths via the spade near the fusebox you were messing about with. so if you tap an earth in like this the stalk will only work if the brown wire from cluster all the way to the spade then the 2nd wire from that spade all the way back to the stalk is intact
If it's accessible whilst the cluster is out, could I just tap into that MFA stalk earth too and earth it to the same new earth point I created for the cluster? I kind of figured this would fix the MFA not scrolling too… are there other things to test for that whilst the cluster is out?
Also, I'm still not clear: can I reconnect the battery negative to test all this? Otherwise how would I know if what I've done is working until I've put everything back in?!
so, if you tap an earth into the cluster brown thats fine, so long as this wire isnt broken somewhere along the way. if it is, the mfa stalk wont have an earth any more if the male spade isnt earthed. hope that makes sense…
engine ————-[spade]—————– clocks
\————— mfa stalk
I guess there's two wires that have to be in-tact to make the MFA work:
1) earth on connector (pin 2) —> spade by fuse box (the existing wire that I'm splicing into to earth the cluster)
2) earth on MFA stalk —> spade by fuse box
Item 1) I could resolve by running another earth to the spade by the fuse box but I tried that yesterday to no avail so I'm thinking item 2) might be the problem. So my question is, can I just splice into the earth from the MFA stalk and run it to the new earth I've created behind the cluster (or anywhere else really).
What I don't know is where that earth from the MFA stalk can be found…
if there is a problem, simply find the 2/4 pin plug for mfa stalk and add an earth to the brown/white wire on the car side of the plug as well then they both have earths, all is fine.
for now if you;'re happy with your earth, hook the battery back up and try it. if the MFA doesn't cycle with ignition on, then worry about the mfa stalk earth
so. if you have lost this earth on the male spade above, then cut the cluster brown wire and earth it to the chassis, this means your mfa stalk doesnt have an earth.
if you dont cut but instead add an earth to this brown wire, so long as the brown is fine to male spade, and wire from male spade to mfa stalk is also ok, then this works fine the stalk will also be earthed by the wire you added.
I'm making it sound way more complicated than it is
I guess what you're saying is - even with the additional earth in place - the MFA earth connection hinges on the existing wire from pin2 to space connector being in-tact. I will hopefully be able to give this a go this evening.
I'll hook the battery back up when I've done the earth splice.
I'm just a wiring OCD snob. even the thought of you cutting into and soldering an unmolested VW dash loom gives me great pain and sorrow
- Aftermarket stereo added
- Aftermarket alarm and immobiliser added
- Aftermarket remote central locking system added.
On that note, though, I have a bunch of those wire joining crimps (little red tubes) but I don't make much of them. Any suggestions as to what to use to join together two cable ends that looks neat and stands the test of time.
a well crimped butt joint is fine (red thingy), VW use them all the time albeit high quality AMP versions crimped with a special tool
Did Brian's "plumbing" bits but ultimately discovered that the pins on the white 14 pin connector on slots 1 and 2 were slight ben upwards, struggling to make contact. So I gently bent them back with a toothpick and that seemed to do the trick.
However, the MFA still isn't scrolling , so I'm on to the next challenge. I push the button on the end of the stalk and it just doesn't do anything - neither on setting 1 nor 2. Would this be symptomatic of the earth to the MFA being faulty?
rubjonny you mention a "2/4 pin plug for mfa stalk" - would that be located somewhere behind the cluster also or where should I hunt for that?
Many thanks for your help and bearing with me this far!
Ben
if it does, wiring is ok your button is bad. if not, wiring or cluster fault
Is this the one? I can’t see much in there that’s not part of a loom / has a connector….
