Cabby rear boot cards.
How to remove them?
Part numbers, Audi: 16186729901C , Volkswagen: N0385491
(watch out for the 16186 part number because it also relates to different clips for a MK2)
Ten clip for £3.15 including post to the UK.
(found another company charging £7.49 for 12 plus post)
Well happy with that!
The company has two sets left if anyone is interested.
http://www.ebay.co.uk/itm/10X-AUDI-WHEEL-ARCH-BODY-PANEL-PLASTIC-TRIM-CLIP-16186729901C-/321171044179
But I got one :-)
Cheers Mike !!!
Massbad69 said
No sets left already :-(
But I got one :-)
Cheers Mike !!!
Chris Massbad69 I've ordered two sets as I found them so hard to find.
So if you want half a dozen I'll send them to you when they arrive!
They will be posted to my Daughter first and then on to me.
Just PT my your details if you want them.
Thanks for the thought though :-)
There's still these on ebay, slightly more expensive! - http://www.ebay.co.uk/itm/VAUXHALL-AUDI-FORD-VW-WHEEL-ARCH-COVER-FASTENER-x10-/321317512887?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ad00426b7
Looks great Chris and great right up - just bought that acoustic carpet now.Massbad69 said
Mike its just black or grey accoustic carpeting and carpet spray adhesive.
Simply, cut the carpet/matting to the size of the card plus a couple of inches spare right round, then spray the adhesive on the card and the carpet, leae for a minute and then carefully place the carpet onto the face of the card.
I then left it to go off for 30 mins and then turned it over and cut the extra and got it all neat to fold over the back of the card.
Then sprayed the edge of the back of the card and the extra hem of carpet and then folded it onto the rear of the card.
Then made holes where the clips go through and put them in.
I do not put the wee circular centres back into the clips when the cards are back in place, as they stay in place without them.
Al in the boot, including a new floor carpet as well, cost me £50ish iirc.
didnt bother with those clips on most recent link. That's a shocker
Last edit: by KPCabrio
Hairyarse said
I ordered a set too - glad I did, looks like everyone jumped on this one!
Yes as you all said, the pins do push out even if they don't look like they will (see top of the post) but thanks for that!
Now here's the kicker.
Yesterday morning I was working to remove the old lights on my Cabby, it was darn cold and windy but I thought it can't be that hard.
I was using an 8mm ring spanner and or a 3/8ths socket and racket to remove the four nuts from the right rear one.
Thought best to do the hardest side first!
I was working to remove the far bottom right nut first which was the most inaccessible of the four. (bottom right nearest the outside of the car)
When the 8mm socket slipped in my fingers and dropped down inside the 1/4 panel somewhere. (my hands were to cold, I should have stopped but)
The socket was from a really good quality set I bought a very long time ago but I got over it because the goal was to fit the darn lights!
So I went a few miles and bought a replacement (not the same but).
Got back to the job in hand and you won't believe it. I did the very same thing again! Straight down inside the 1/4 panel.
OK, enough is enough.
Went home and got a telescopic magnet.
Now here's the real kicker, the body of the car has a far stronger magnetic presence then the sockets I've dropped (they are magnetic).
The whole they have dropped down are far to small to even get a childs hand down inside let alone mine!
Not only that but of course the bodywork tappers to a very narrow point at the bottom.
OK, maybe in hindsight I should have removed the roof 'Ram' first but…
So now what the Hell do I do?
I can't be the first, can I?
I changed the lights and was really really really careful so managed ok BUT, when the dent guy came, he removed a rear light to usu the hole to get to the reqr quarter.
When he put the light back on he dropped the nut down the hole, so I have 3 nuts on my passenger side light next to the ram.
Chris
Chris
Sounds like the same as me kind of!
But I have changed them in the last few minutes, what a pain in the butt that simple job is.
Anyhow, if you need a spare nut or two I have some so I can post them to you!
