New Pads?
(In Topic #183058)
Mk1 Golf 1.3 Driver
I need new pads for our Golf Driver but are having trouble getting hold of them…
1.3 Driver 1983 with standard brake set up with the 2 pin arrangement. Have found 2 different sets, same height and width but 18.5mm thick and 12.5mm thick. Any idea which are correct? Can't work it out as my old pads are heavily worn.
Normally I'd just buy both sets but can't seem to find anywhere that has them in stock to physically look at and don't want to order both sets only to have to send them back. So second question, any thoughts as to where would have them in stock apart from Gsf, Euro car parts, etc (vw heritage have a 1 week lead time on 1 type and immediately available on the other).
Cheers in advance.
When I had a Mk1 Diesel Jetta with the same type of calipers as the Driver I once spent an hour or two trying to get some 'fat' pads to fit…..
Measure the discs and then decide which pads you need.
For the cost of new discs, if the ones on are not perfect I'd swap those too whilst you have the wheel off and pads out.
I have the small square brake pads on my Scirocco with solid discs and have a new set of brake pads in my shed I can measure for you if you have solid discs.
Calipers look like this?
I've got solid discs. And yep those are the same calipers…except mine and now way near as clean as those! I imagine a lot of scrubbing sanding/cleaning went into those. What caliper pain did you use out of interest? My dad is keen to get his done.
If you're happy to measure the pads and let me know a cost if they're right then that would be great.
Cheers,
Cheers,
Car parts 4 less seem to list your car as having 15.2mm pads….
Link to Car parts 4 less (sister and cheaper company of Euro car parts, notice the website is the same layout!) they will do free delivery and pagid are a good make, they don't list my 1978 Scirocco so I did not search here when buying mine. They are £8.94
http://www.carparts4less.co.uk/cp4l/c/Volkswagen_Golf_1.3_1983/p/car-parts/car-brakes/brake-friction/brake-pads/?101440048&1&08a876eb6bed9478ac4bedf853cba1b496ac0521&000036
Euro car parts list the same pads for £14.08
http://www.eurocarparts.com/ecp/c/Volkswagen_Golf_1.3_1983/p/car-parts/brakes/brake-friction/brake-pad/?101440048&1&b7faf0ea3390d4a0149ef931228fc20aa9b7b625&000036
The ones I bought from ebay are the same Unipart number as these GBP 682. I think I also paid £1.99 for mine but the postage is £5.49.
http://www.ebay.co.uk/itm/VOLKSWAGEN-GOLF-MK1-1-1-1-3-POLO-SET-NEW-UNIPART-FRONT-BRAKE-PADS-/281137318882?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4175170be2
My Scirocco brake calipers don't look as good as they did in the picture now as that was when the car was off the road for a restoration, the calipers was band new and had not been used when I painted them so no scrubbing and cleaning, I used Halford brake caliper paint but it does chip off if you are not careful putting the wheel on so they could do with a touch up, the car is finished and now been on the road for 4 years and the paint has kept its colour.
I've ordered the set for carparts4less, like you say Pagid are a good make and don't see why I should pay double the price from EuroCarParts!!
Seeing yours nice and shiny like that has got me wanting mine like that!! Might be a job for next winter when it's off the road anyway for welding!
Massive thanks for your help with this!
Any thoughts r suggestions? I've tried taking the reservoir cap off to allow movement of the fluid but like I say, no success.
Bit concerned though, as the other wheels pads haven't worn this bad, so wondering if the piston is sticky/ seized as one pad is completely wrecked and the other isn't too bad!
Cheers again!
Thanks for the help again!
Are the VW II calipers you talk of from the Mk2 Golf? Not sure how far I want to go with an engine upgrade but possibly 16v. Reckon these brakes/calipers will be up to stopping that reasonably?
