v5 mk1 golf project
the start!
Managed to get a nice look at the floorpan wall bit! Not sure what it's actually called, anyway! It's had some sheet metal welded with a ton of mastic around the edges! Plus some more rust
I'm not sure if this is an easy fix? But I'm hoping some one can tell me it is! Worried there might be more rust hiding from me! Seems as if the last owner has painted over most of it!
Alex Butcher - V5 powered MK1!
The old wheel…
so I managed to get myself a steering wheel for £18!!! bargain right? turned out to be the wrong size fitment!
The wheel that doesnt fit…
apparently the early golfs have the smaller spline (correct me if I'm wrong) so I needed the steering wheel to match.
which ment getting another wheel for a not so bargain price of £80, but I must admit I like it a lot more!!!
The newer and hopefully perfect wheel…
1983 Pirelli Edition - http://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=view&id=165792
Also managed to get a fuel pump bracket and foam housing! But the bracket is to rusty for my liking even after a shot blast! So I've started making one! Let's hope it goes well!
want some like:
dont know what the last owner was thinking!!!
Last edit: by butcher103
Looks like you've got a canny project on your hands mate.
Two inner wing panels
whole front panel
Left and right lower side sills
Fuel Filler panel
Rear boot lock
Go kraut Front crossmember brace
Go kraut Chassis performance subframe
I'll be replacing the inner wings, front panel, rear panel, possibly sills and each side of the scuttle panel plus a couple little bits here and there.
Any tips, tricks or things I should know when welding a mk1? Also what underseal should I use?
I've just been getting a welder myself and trying to learn how to weld - its not as easy as it looks
The thing is it'll not be cheap buying a welder and all the bits you need, gas, mask, wire etc. I think mine has cost about £300+ and the welder itself was secondhand.
I've been lookin at all sorts of welders, the thing is a couple hundred and some practise means you can do so much more yourself.
Thanks Panch_mk1golf , you don't see many of them, think a lot of people dislike it, but it's the sound I love
Good thing about learning to weld is you can fix your own stuff whenever or help out others/make a little cash
Little taste of what I want it to be like…
