MK1 Cabriolet GTi 2.0L, Helios, Restoration - MORE UPDATES!
Lots of work ahead!
Need to finish my boot re-vamp and get my coilovers bought and fitted
1990 - Cabriolet GTI 1.8 (DX)
Some pics of the progress!
Final part of the underlay put down, you can see i've also remove the knee bar, stereo and put the steering wheel on.
Need to grease up the runners before I put the seats back in but will do that when it's all finished and ready.
Looking first class already! Is that new carpet to?
Yeah it's a newton commercial carpet, had it a month but obviously this is the first chance to lay it down, I've got the front to go in soon but going to sort the wiring out first and replace the doorcards with black ones I've got. Trying to find a black centre console and knee bar at the moment so I imagine it'll go in when those have been fitted.
1985 Cabriolet GL
Some of you will know how tight for space the MK1 doors are, which proved a pain when finding somewhere to mount the solenoid. Finally found a good location which gives me enough room and doesn't compromise the doorcard. With some bending of the wire and fiddling it was finally working. Got to do the other side later in the week then thread through all of the wiring. At one time the car had an alarm which means it's already got the LED blank in the dash, so I'll locate the LED to go there. Once all of the wiring and electric windows are working again I'll get new door membranes and clean up the inside of the doors but for now they are just loose, plus I still have 5 sheets of soundproofing left to fit - no point sticking them to dirty doors.
Anyway here's a little pic
Giving a break from the wiring I decided to test fit the door cards to see how they looked, I need to clean up and lay down more soundproofing on the inside of the doors before I put a new plastic membrane but I couldn't help myself dry fitting them! I also fitted the single lamp front grill, looks a million times better than the debadged on that was fitted originally but sadly I forgot to take any pictures… got some of the doorcards though!
Inside looks like a bombs gone off but it looks worse than it is, once the indicator/hazards issue is resolved then I can put it all back together and put the front carpets in!
Anyone else just love wiring?
Last edit: by Darren5591
Someone had put some Crystal M3 lights on mine, within a month I had sourced and put back to stock
So much more to do but nothing that can't be done with a little bit of time, can't wait to actually get out with the roof down with the weather being how it is! Still haven't had time to fix the indicator plug issue but quickly washed her down and put the new bits on this evening. Here are a couple of pics of the progress!
My lock grommet is probably in need of replacement, are they easy to fit or a pain in the …?
Matt
Last edit: by shaunyp
Going to fit the door membranes in tonight so I can get the new doorcards in properly, thought I had a leak when it rained the other day but it turned out to be water dripping off the window runner and through the unprotected doorcard slot!
Popped all of the side trims on with new clips last night so they will hopefully keep attached instead of dropping off.
