02j gearbox tower
(In Topic #173942)
Am looking for an 02j gearbox tower! Something like this:
I've been to a couple of scrap yards and found nothing, and people with gearboxes on ebay don't want to sell just the tower :/
If anybody has one that'd be fantastic!
Many thanks
'82 c formel e - 1.8t 20v
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
collo16v said
I have one still on my 02J box how much were you offering? as I was only after 75 quid for my box and corrado shifter +cables
Oh great! Would you accept £30 posted and include the cable ends/connectors? Just in case it's a different style fitting to the end of the cables I have at the moment. As I believe there are three different ends: a thin peg, a thicker peg and a ball type fitting.
Many thanks!
Mk1 Jetta (Jessie) build thread here
View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
T25 westfalia camper, 2.2 Subaru powered
vw touran 1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck……. www.jsgarageaberystwyth.co.uk
I have a late one £50 posted
funk-star said
Corrado one won't be the same if you have removable ends. You need a late 2001- tower to get the removable ends.
That sounds good. Could you get it posted out first class tomorrow? I need it asap really as I am currently using an 02a tower in an 02j box with an 02a shifter and the shifter has broken so I can't get reverse a bit of a pain. So basically I need the 02j tower to fit my 02j box so I can use the 02j shifter that's currently sat in my garage.
Also another question, as I plan on mounting the shifter inside the car I obviously need to run the cables through the firewall. How do I go about disconnecting the cables from the bracket? As I obviously cannot run the cables through with the bracket still attached. Thanks
Also I'll message you details in a mo
The shifter is from a mk4 golf, where is the best place to put the holes in the firewall?
Also a pic and paypal details has been messaged
Cheers, have sent the payment.
funk-star said
I would of thought you would run them under the car as per mk4 etc?
Got the tower yesterday, thanks a lot.
I took the 02a tower out my 02j box, the parts that actually go inside look identical but it seems like it doesn't want to go in, is there a technique or does it require a bit of force to get seated again? (It took a bit of force getting the 02a tower out)
If it doesn't let me know and I'll send the one from this box.
funk-star said
On the under side of the box, opposite to the hole for the tower there is a cap held on with 2 screws. Drop that off (will drain all your oil) and see if the cap fits the shaft on the tower.
The shaft diameter is the same as the 02a one that was fitted so I assume it should go in. Would it be easier to remove the cap at the bottom, fit the tower and then install the cap again? It seems that last bit is where it's having difficulty going in. Thank you
Worth trying it on the shaft tho.
