My 83 driver rwd project
The plans simple :) take the shell fit engine in the boot done ;)
By the time I'm ready for interior my work should be doing carbon fibre so could see a carbon mk1 dash
Matt
I'm currently at the 12 hour mark in the cage
If I was mig welding the cage I reckon I could of shaved a good few hours off
But I'm tig welding it all so flush fit or very minimal gaps mean a lot of tweaking and that's what's taken time
Roll hoop forward I've done the hard bits so next weekend I should get another good bit done
Not said that very often but then this is the first time I've read this post!
Outstanding work mate and I for one will follow this very closely, so thanks for sharing!
golfcabrio said
Insane and brilliant in one sentence!
Cheers bud
Again soon as pics are available I will post em
Best part about it is it's £30 a big box and my bits are costing £10
Bit more progress this weekend
After some trapped fingers and many swears I managed to remove the cage in 1 piece
This is the only picture of the removal lol but it was a very precise procedure
With the cage out I had access to all the joints and able to fully weld it
Couple of hours and it was welded
Nice simple roof cross
And a quick mock up of head clearance with me helmet
Only had 100mm box but the cage sits 130mm higher then the seat base so will have a good 70-80mm head clearance if I ever decide to track or drag it, my old fiat coupe 20vt was horrendous for head clearance with the same helmet I had to drive with a bent neck not good
Treat myself to a long acre 17" mirror
Next job remove all the sound deadening
Learnt the easiest way after doing my track clio gas axe and a scraper
And all the removed sound deadener must of been a good 8 kilos worth
And back across into other workshop parked up with the dimma
Made good progress on dimma aswell nearly a full hoop forward cage done along with the work on the golf
Next up is remove the worst of the under seal in the archs and I have a mate who is going to sand blast everything but the exterior panels
Seeing some of his previous work on rally cars and my work mates dimma it's going to save me a lot of time I've put 3 weeks into what I've removed upto now and there's areas I can't reach with the knot wheel he will have the lot done in a few hours
Your unit looks a great place to be!
Matt
It's turned out a lot better then planned upto now
Yea my works a sweet place
Hairyarse said
Fantastic looking cage, still trying to work out how you got it out in one piece!
Cheers bud
The 1st pic of this weekends progress kinda shows it slid back and dropped
It's basically just keep dropping it on the back and pushing back until the hoops rotated 90 * and flat on floor and then lift body over cage
Hairyarse said
Still doesn't look possible to me, you must have had Dynamo helping you out!
when it goes back in I will make sure I get loadsa pics.
Last edit: by MrVrG
