My 83 driver rwd project
The plans simple :) take the shell fit engine in the boot done ;)
this reminds me of a lupo which had a vr6 in the back although that also had a vr6 in the front and he put nos on each vr and last I saw he was about to twin turbo each one
'83 1.3 Golf Driver GT - Project thread
Instagram - matt.semp
That said, it's down to you - go for it if it's the look you're looking to achieve with the car
Long way off interior decisions
Sending my front shocks off today to shock tec
Adjustable dampening coil overs
Put some supports into the bay accords to the wishbones
These will also become a base for my alloy fuel tank
Tigged up well for some old steel
Windscreen out
Just cut the rubbers
Next was the start on the cage but first I had to remove more from the interior
After a few measurements and some working out for the bends I got the hoop right in 1 go well pleased
Hoop fitted and then the side/door bars
Next up I trialled a seat to work out where the harness bar should be
Also got the roof bar in
Put a dash bar in which got lifted later on
And a start on the door bars
Near enough perfect fitted
2mm gap
Another bargain my mate bought a 1.8t engine from Spalding and the seller had this £10 well chuffed
Wiper removed and a front view
And some dirty rott
Second door bar gone in
Another try with the fibreglass dash
And onto the bar that goes from shock turret to the main hoop a 3 piece nightmare this took hours to perfect
Looks so simple but getting the 2 main door bars in line perfect was a nightmare worth it but still annoyed me until it was right
With me being good part of 6ft tall high door bars was out the window which slightly effect the angle of the 3rd bar going to the shock turret nothing major or noticeable from the outside but again slightly annoying
Next up was some fancy tie in plates to join the cage with the body
Usually we have punch and flare tools but with my cage running as close as it is to the frame work they was too big
So I ended up punching a 17mm hole in the sheet and improvising
Good old press and ball hammer and 5tons worth of pressure
Not bad
And finally some pictures outside
Think upto now I've put 15 metres of steel into the cage lol
Next week will be doing more cage work and hopefully have some engine bits coming to strip and rebuild
Keep up the good work
Andy.
I've bent 10 hoops one after the other same setting and they will always be a couple out
Still not feeling that dash
At the minute I'm still hoping to use the original dash just a tad trimmed
MrVrG said
Hairyarse it's still just a option at the minute they also do a full carbon version
You don't have to worry about my opinion on it! lol Carbon sounds good though
