K-Jet Help Please!
mark1gls said
If you want Bosch stuff I can look up the part numbers as I've got my old ones as spares in boxes, I get my Bosch stuff from a Bosch dealer/motor factor, have a look on the internet or yellow pages to see if you have one local to you or check on eBay.
I'll get the numbers tomorrow if needed
Thanks mate I shall try and look, I just want everything brand new, dizzy, rotor arm etc :)
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist] have all of the bits you'll need, beru make just as good as bosch
Guys! My car cut out again tonight, I took one of the spark plugs out and put another in and put it on part of the engine to see if it was sparking when turning it over, it wasnt sparking, but, I kept turning my key in the ignition and every now and again I was getting a small spark then it would stop, it eventually turnt over, please help as I think this may be able to pin point the problem?
so did you renew all of the components yet?
if so next time check you have live to the coil +ve with ignition on AND cranking. if not check the black wires back to the fusebox, ignition switch and the ignition switch itself.
if thats ok then look at the tci unit, coil and dizzy wires next
