Jessie the tdi mk1 jetta (haldex conversion begining...) 12/09/17 update!
IMG_1881.JPG IMG_1882.JPG IMG_1883.JPG IMG_1884.JPG IMG_1885.JPG IMG_1886.JPG IMG_1887.JPG IMG_1888.JPG IMG_1890.JPG
So the syncro rear axle got a seeing too with the grinder tonight, all old bracketry cut away and dressed back, tried the haldex in to try for size, and started mocking up the bracket kit for it, looks to be a snug fit!!
  Mk1 Jetta (Jessie) build thread here
 View topic: Jessie the mk1 jetta (pd conversion) lots of pics!! - The Mk1 Golf Owners Club
 T25 westfalia camper, 2.2 Subaru powered
 vw touran   1.9 tdi remap, Bbs rep wheels , lowered, bla bla bla……… Wife's car
2013 Vw amarok 2.0bitdi, work truck…….  www.jsgarageaberystwyth.co.uk
IMG_1934.JPG IMG_1935.JPG IMG_1936.JPG IMG_1937.JPG IMG_1938.JPG IMG_1939.JPG IMG_1940.JPG IMG_1941.JPG IMG_1942.JPG
Ok so got some more work done on the rear beam today, all welded up haldex fitted properly without the jig, just need to get it blasted now and ready for Powdercoating, collected my gearbox yesterday from martin Emment of gas and gears in Bridgend, it's been fully rebuild with new bearings and seals, preloads adjusted and arp crownwheel bolts, vagabonds rear mount fitted along with a pinion brace too, got to strengthening the clutch fork today too, just incase……
So next job on the list is to collect my rear arms tomorrow to mock up the rear disk setup and then they can be coated too…….
Welcome back Jamie
That's a bit of a beast now!  :cool:  :thumbs:
So rear arms are back, blasted and ready to modify for the caliper carriers, loosely fitted the arms to the subframe tonight, MY GOD it's wide! Looks loads wider than the mk1 beam!!!! Time will tell when I remove the original this weekend! Trial fitted the axle mounts with new bushes too, all looks good there, just need Timorese some correct pitch bolts as the temp Ines I have are not what I want,
Car stripdown begins tomorrow night hopefully, engine and box coming out…… stay tuned……
This is just incredible!  Fantastic work.
Fully restored and driven daily!  I love my 1980 Rabbit Diesel!!
IMG_2057.JPG IMG_2058.JPG IMG_2059.JPG IMG_2060.JPG IMG_2061.JPG IMG_2062.JPG IMG_2063.JPG IMG_2064.JPG IMG_2065.JPG IMG_2066.JPG IMG_2067.JPG IMG_2068.JPG
Today was a busy day, engine and gearbox out, all suspension removed, fuel tank removed, jig mounts built, car mounted to the jig and rolled over, now to asses the car, few little bits I need to sort, axle mount drivers side needs a repair as one of the studs snapped off, and sill lower lip has been folded over due to being jacked up on, so nows the time to get that sorted too,
Tomorrow's jobs are
Remove spare wheel well and rear crossmember
Clean off sealer and trial mount the axle
 Lots done today, let's the pics do the talking!! IMG_2072.JPG IMG_2073.JPG IMG_2074.JPG IMG_2075.JPG IMG_2076.JPG IMG_2078.JPG IMG_2089.JPG IMG_2090.JPG IMG_2091.JPG IMG_2092.JPG IMG_2093.JPG IMG_2094.JPG IMG_2095.JPG IMG_2096.JPG
IMG_2098.JPG IMG_2099.JPG IMG_2102.JPG IMG_2103.JPG IMG_2104.JPG IMG_2106.JPG
Plenty done the last couple of nights, spare engine block and gearbox mounted within the car to mock up for the propshafts length's, also measured up for the o/s driveshaft, propshafts needs shortening by 8 inches and the drivers shaft also needs shortening, but I had a little brainwave this afternoon, I would strip the 4 motion skoda rear shafts and check them for length, low and behold the n/s/r 4 motion shaft looks to be the correct length for the o/s/f shaft! Result!!
Got to making up the rear axle mounts tonight, got one side made up and tack welded into the car, took a good three hours to get that right! But kept all the cardboard templates so the other side should be much quicker!
So tomorrow nights plan is to get the passenger side mount finished off and then set about fabricating thebdruvers mount, more to come…..
IMG_2109.JPG IMG_2110.JPG IMG_2114.JPG IMG_2115.JPG IMG_2116.JPG IMG_2117.JPG IMG_2118.JPG IMG_2119.JPG IMG_2120.JPG IMG_2121.JPG IMG_2122.JPG IMG_2123.JPG IMG_2124.JPG IMG_2125.JPG IMG_2126.JPG
Getting very interesting now.
Lots done in the last week, axle mounts finished and ready for sealer,  finally found me a pair of rallye rear caliper carriers 😍😍, rear axle rear mounting plate made up and bush fitted, rear crossmember fabricated and welded into place, boot floor template made up and cut from steel tonight, screws into place for now until final trimming is done and then that can be welded into the floor…… rear arms off for Powdercoating tomorrow, I decided on and colour as of yet tho…….
23FC9C5B-4886-4712-9266-8F00B7EC65E5.jpeg 0954CB09-DC81-4A62-A712-573194FDE271.jpeg 47E15F9A-A4C6-4D52-A394-78D1632CB5D6.jpeg EA3AEACD-61D5-44AB-90DF-3EB76CE11A4E.jpeg B7B3B623-CC44-4F6C-9FE3-30311E94CB00.jpeg C88779E3-C3BF-4F3C-B412-B5F3E05387ED.jpeg 2290FC57-7CF9-48D2-9F9D-CE33A88A0697.jpeg 512011E6-ABF8-45A3-85DF-5864611C161B.jpeg E12D7E40-DF26-4192-B531-D8D59A6965EF.jpeg C4707769-AE53-42E2-A544-95A8E744C80D.jpeg B668CDFD-8636-4B56-82AC-89A7C047991C.jpeg 3FD2BF51-AA78-47B8-B861-53395141612D.jpeg 199D374B-F985-46C0-8B8D-4C0EB7EC84C6.jpeg E7CE243A-780D-40B8-BF84-4C8CA4A74B16.jpeg FA864DE8-914E-412B-9C63-8A1B90A904EB.jpeg 9BBEE565-B23E-49A2-B327-1E070E587EBE.jpeg 77B9A928-CEC9-45C1-9F1C-C54282444448.jpeg 2339343E-CB27-4FFD-8142-DEC0FDD72F42.jpeg
Great working going on there. Loving the fabrication work.  :thumbs:
I would love to have a haldex on mine.
You're a boss man! Mine next! 😘
Plenty done since last update,  boot floornin and finished, fuel ya k situation worked out and organised (mk2 escort efi boot mounted tank) battery rocation box built into the spare space u see the rear seat, sill ends capped off and welded up, camber and toe adjuster kit welded to the rear beam so we have some geometry adjustment,  axle and all accounted parts been for Powdercoating with all new power flex polybushes, tunnel fully raised and gear selector sorted, seam sealed most of the floor pan apart from inside the rear arches, one rear turret Finnish last night, just needs dressing back and some sealer, steering rack mounting points lowered to allow room for the prop shaft, each column joint extended….. drivers turret to do tonight….. planning to get the underside cleaned and coated in raptor this weekend
F561D701-89BC-44CF-BA22-3D2C9F1229CC.jpeg 5D6AEEC2-9236-4061-9322-43594EEC5B55.jpeg 5BA4BF63-94E9-4FAB-81A3-BB1815F669B5.jpeg 78A14394-D49B-4802-9F5C-51AE6119149C.jpeg A0F17548-A6DE-427F-BB22-0FEC80553F68.jpeg 8F19A0DF-A535-49AC-BDED-0EFF160247CE.jpeg 78995D02-3602-40FD-8635-DBB64D34E904.jpeg 6B721688-9DA8-4604-BD3E-8087C1F4FC5D.jpeg A7574CAD-E6AC-4D9E-85FF-00AC9C7B47EB.jpeg 62320EFC-FBF0-46D0-A4F1-AF326999A8E0.jpeg C51D38B3-15D8-49E6-A34C-7AB87CCEB35D.jpeg C3EF09D3-91A5-4E5A-BF9E-A23FC8BC2F7E.jpeg 63EE82D5-F3B4-4677-A035-77F2AED394D8.jpeg 10CB081F-AA70-48B4-A9B7-898C7A568DBE.jpeg 97D81ED5-8A37-45DE-900A-E7AE84763FFE.jpeg C645252D-D27A-485E-BA65-B4022FAD7217.jpeg 5CC9E546-9857-48E2-86C7-BDCB6EE9E7BB.jpeg 4C347DC6-EEE0-4A32-92F9-3F5A0EDF209C.jpeg 080D6399-3581-45B2-9C43-7F8FF5B7F7DA.jpeg 3B906351-FEA2-47CB-B9EE-CE9EA0708E3B.jpeg 5956444F-59D4-4DE8-90B9-B5B5E7E2F1FB.jpeg E9608748-A54D-42AF-A55E-31C3EE695660.jpeg 5AD7545A-1E98-4A3A-9ACD-6CE5FD3E6FDB.jpeg 47493B65-52B2-4012-A9C2-4CA71BDAB69E.jpeg B6E2D715-64D2-4120-B47A-64829015FD6D.jpeg 9FF7E727-F559-4349-9CC9-E0DFCF5679FF.jpeg 7A65A5B9-4218-410C-BD02-F7000D750106.jpeg 06191F6D-6687-491C-8D47-B209AE2C100A.jpeg 5AB3D3D3-4631-4932-9DFD-711BD8FBD06F.jpeg 784F800F-F51C-4D79-8172-8077EE9D25A8.jpeg 1DC69AC6-1927-434C-A88F-47643378C86A.jpeg E3115AF0-DFA5-4293-A187-449DB2C58CF4.jpeg 7C8797AD-9628-4337-AC0D-2C489AD1A17B.jpeg C9694EFC-5E39-4E9D-84BD-B90B4E09F735.jpeg E88EB6C2-ACF6-48EF-BD01-6B88AB835A06.jpeg FC282085-2B8E-43BF-98A6-EACFBFF19E1E.jpeg 8592CE9B-30F9-4694-8881-B6EC4604E1EB.jpeg 72B2472E-C57F-414D-8621-E4C7052DAE72.jpeg 2EC00E6C-5AB2-43A9-91CB-25D9F87D5925.jpeg 390F4C4C-BB90-4603-86D6-B2182A499ADF.jpeg BAF4BA53-07C8-407C-9A98-343BA1841DF8.jpeg FC80B90D-A841-427E-8195-E34E9A912E46.jpeg B6388D4A-B9A8-48B6-B53C-9189280B3C7A.jpeg 0395E474-F5C5-4777-9DF3-4570F8D44225.jpeg 69A8FB8F-E5F8-4CAA-92A5-5229EE14B4AB.jpeg 37D48174-21DB-4F12-AF9C-06170CA77334.jpeg 783C0616-883F-410A-ADDE-FFC7B690D9B0.jpeg A1A34876-DDF7-44A8-AEDA-7C78A1808AE9.jpeg DAD7F4F0-3691-4AF6-A29D-58C075E1CAF6.jpeg DDF464FE-B7AF-43C7-8FB1-4065672B23AB.jpeg 6EA79369-7EEF-4D8A-BC31-F020D7839C94.jpeg D0F664C1-0D3E-4038-A60D-7517ED330479.jpeg BEE7EC55-0E34-47F0-B612-C1E2B5CFF8C8.jpeg 4BA75FB0-8EC9-4B34-90F2-DCE79A64B725.jpeg 5A28D18D-861C-457D-9EE8-7670E54424FF.jpeg 0F0BCD4C-3D44-4322-84BD-33E715FC8D4C.jpeg 4BF93773-BA70-476C-B2A8-395DADE86504.jpeg EF23E179-73CA-4054-8F69-9E86CF06D5DB.jpeg 3955D1FE-741C-4EB6-A2B8-B86EAA5BAB3E.jpeg DD63AB22-12F0-4D54-98D1-D7B44CEDD404.jpeg D1FDFD6D-8869-45E7-9D7E-D6191F3EDB20.jpeg 35E69656-97ED-47BB-ACA6-BA3A3B4CFF14.jpeg 57D59AE3-3A14-4F33-9E01-58D65867B676.jpeg 0A634BD8-9862-4BD7-ABF1-CEEBB15125A2.jpeg 07A94269-7D71-4495-8D1B-D3462129065D.jpeg DA13AC4A-2DB7-4AC8-A86E-E1644A0EE928.jpeg 68E78B96-CF23-4538-AEF4-1EC9781A1E94.jpeg 81072CEA-C45D-4E1B-B351-ED5BCFDB71A4.jpeg C571C2A1-4782-4845-9881-D98183242A98.jpeg 5A207DE0-CBD8-4B97-8530-1BFD3AC60745.jpeg 149D0332-49C9-4E25-8A26-142BDEA830BE.jpeg 71988FB0-D2A1-4873-8CED-31648C14EC64.jpeg 5C1BD308-E6B2-4E7D-9723-58F48141325F.jpeg 76289821-52D8-48AD-8A41-A51B6156A645.jpeg E7CCEC82-1D71-4AF1-9839-4EEBFFB38F0C.jpeg 865905E0-5F0F-4D09-BA85-6130FF31A92A.jpeg 02431616-68BA-410F-AA19-8534650F8540.jpeg 2B36BD51-380B-4E3B-B081-396AB62F45F9.jpeg 0F0FF1FD-404A-465F-8C00-E7D56FA47069.jpeg 431E134A-2D55-46DF-86A6-91037323C9B2.jpeg 3B60F002-9D3C-48E8-BE59-2F654EC13613.jpeg 5D1DED44-4C9E-416D-A2AD-C37F4F25D258.jpeg 9E6D4BB8-45E3-49AF-ACA8-DD3F03179C23.jpeg 1AAB9BEB-F7D5-451E-9556-DBDAA3A7D089.jpeg 053F8419-E4C4-47D3-9817-C30CBC8C7A82.jpeg 36A63B48-8686-4184-88DA-72A92BBBA4E8.jpeg 2FD714BF-2E3E-4812-9CAD-ACCD220D31AF.jpeg 16373A10-0C0F-4012-8948-DC232BFE7C30.jpeg 518F9605-851D-4B91-900D-F687A7340859.jpeg E03EBFB1-DEB7-44A3-869A-B109F19F1563.jpeg 55AF079A-E742-4F12-A388-EE56BCB219EC.jpeg D0BCECBF-B4C6-46F4-A130-BBE910F67E86.jpeg DD9F7F20-6C88-4D9B-A39F-967573579480.jpeg 2D852063-2CC9-4B22-9C23-EEBD4A4BD97E.jpeg 2DAA9864-9F2C-49A0-BC92-3E67F1D0723F.jpeg 31A10984-4EF9-4988-AAA9-AFC8747C7911.jpeg 4BACCEA3-2A88-4C5D-B806-DB4890A9D5D4.jpeg
mad skills that's a great project you have  ;)
DANBOY.
Mk1 Golf cabrio "Golf+ absolutely cabulous"
fresh 20vt rebuild well underway :)https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmy-old-white-cabby#post_1402754
74BE9131-5EAA-4CA9-A2C7-AC9F6506EA18.jpeg Really need to update this post, car was completed one week before gti spring fest at Santapod, and some testing was required, so we loaded her up and trailered her down, just incase anything broke 😂😂 pics and vids to follow 385BA571-7166-46AE-B1CC-5BA764ED96CC.jpeg 38332607-C8C8-4B0A-AA8C-86F0754437F8.jpeg 06E510B2-39A7-429E-B816-76605CDF1D49.jpeg 176DF47B-6270-45A3-B99B-C39E46AE0BFD.jpeg F3A8C718-1646-471F-9BEF-4BDD6F9EF066.jpeg 9BE9525D-20CA-4CA3-94DC-62783FFCEC15.jpeg 05DE9A94-97E7-4AB3-AC2A-C1000C4012BA.jpeg E82F78D2-4A37-407E-A2A8-E80D0BC13A33.jpeg 1C566A55-5E4E-4E0B-AE79-750901B13438.jpeg E260D7A8-0903-4C50-8A5A-583C60A9C6B0.jpeg 0909C2FC-12F7-4474-BE21-3351D1EB929D.jpeg 775F2DFF-0694-4A6E-A31E-483CB1809A28.jpeg 3C2DD139-F5E4-477F-8C2C-9680AFB317F6.jpeg 80977216-056A-4634-87FB-CC03BE194352.jpeg 10F76C36-C90A-47B7-8869-22CD651A9A25.jpeg 3C033660-A760-45D2-BF70-6C7FB5C8DFB9.jpeg A1C96695-BD01-4A34-963F-C7DBAE6726AC.jpeg BF36B9A7-BEEE-474A-BEE2-49A19FF508D2.jpeg 85341BC4-68BD-43D4-81A5-C362276F7B70.jpeg DD4DBDB3-4F9E-4FE3-A5A0-BA3F6759B29B.jpeg B9666937-C2B2-40F8-82CF-465B54455951.jpeg 40BC2937-6E77-4756-B939-48BFEAE2A715.jpeg 65D5EF61-D8F9-4C44-88DC-4E079AB3E48F.jpeg CE6DE157-A15C-4923-A9E9-D8A832A1F7CD.jpeg EEB9C7AB-A37B-41F0-A5A9-C035498036F9.jpeg 2CFEA5B3-7964-4179-9703-F0DE97505903.jpeg 13799307-E74B-49D1-8329-71B3E55107D9.jpeg 85C83A62-FB07-46B3-A452-D59928C59DAC.jpeg 3F4678E5-104E-489F-8596-0F886B813058.jpeg 32253ABB-F81D-4711-A697-875F5458E984.jpeg 112459CD-09A2-42EE-BEF4-243D6CE450FA.jpeg 545EA2E0-C2C6-4DAC-A392-0369A45EDA89.jpeg DC8C1B83-ECE9-4B0E-B54E-01A79AF59A59.jpeg 90F030BE-736C-4089-A5EC-DFD79872E938.jpeg 9EA0658B-3431-4C4E-A8F2-6757EEA1D626.jpeg 35C77341-FCA9-403D-B284-6E17735618BD.jpeg AD096755-FF59-4B2E-AC66-9F102AAAE3E3.jpeg FB29F75C-F062-4A9E-843B-E18D322C6158.jpeg 218A8AD2-AD3B-4061-A273-58674FBEFFF7.jpeg D2511B61-3713-4688-9F78-BBB388A4F14B.jpeg D473CB43-FA03-4F62-9026-3FEF5A8969B7.jpeg F1D45E5C-333B-484F-B81E-E0C92BE10B47.jpeg 962AFB88-54BE-4B0A-91EB-CE15BED9CF8E.jpeg 253D0B35-3B8E-4028-82F8-B7E61E94CCD4.jpeg D7B6D197-C34B-4450-A0DA-D8B1FE2E2257.jpeg EECC5EB1-7DE3-45EC-8F0A-D4C746963929.jpeg 7610DDC5-735B-4D36-95D7-563AFF5C7782.jpeg 483EAB4F-F41E-42E3-A84B-7C0EF0C27E9E.jpeg 640408F9-9FA8-4FB3-923C-5460572D0612.jpeg 9A42D878-C07C-40F5-89FF-902729C88FD2.jpeg 6C5D9494-0500-477E-AE1E-458D191ECBE8.jpeg 26852F9E-398B-45E5-B3C2-6413C08CCCE9.jpeg FB32C508-FFB5-4ACA-9E79-E12AA56B6B22.jpeg 0001B3CC-0ED8-4D64-83C0-CFF00872AA4F.jpeg 783CEAC7-6AFE-4FAB-A1BE-F7AB13905C4B.jpeg 0369E9F9-58D7-4205-B74F-E888E55A9DCA.jpeg 3119DB2D-E866-47F0-9FA3-E223B95C0A1F.jpeg 577F5BCB-AD60-467C-82A6-B77ECFBEEBD6.jpeg
F9CC25FE-92AD-4465-9482-BBF2393006BE.MP4 6913D661-9F78-4274-8791-8924F0DF6EEC.MP4 C83CAEC4-83F3-4348-AD4E-992ECFA35A75.jpeg CF9E6CFB-D7AB-40CA-ACA2-AEAF97071DCF.jpeg A2CFB14D-B16D-4B4A-BD00-7CD4A363760A.jpeg
Last edit: by jamiegolf
