MK1 16v GTI Caddy
A small update for this week, the caddy is in the workshop, on its revolving stands. I have removed the front and rear axle, so i can get on with protecting the underside, as you can see its only been primed so far, apart from the engine bay and wheel arches that have been paint Lambo orange of all colours; unfortunately this wont be stopping at I have other colours in mind.
The fuel inlet has been moved the inside the bed, to conceal it and give a much tidier look as well as the inner side panels of the bed, which have been sheeted across the top, which I think looks far less commercial and overallmuch nicer.
Also got a good look at some of the front assembly, A pair of FK coilovers, and some BBS RS Alloys which I Believe to be genuine (Fingers Crossed) The seem to have the correct markings I:.
Matt
pazwaa said
The shell looks in great shape, will look fantastic when finished
Matt
Thanks Matt,
The shell was the main reason for me buying it, im far more interested in the mechanicals than the body work side of things.
Matt
Thanks, its cleaned her up a treat and I surprised myself at how well it came out.
Body work is now in full swing, ive spend a good few hours so far rust repair, priming sanding flatting etc, and tonight my mate came across to lay the colour down.
Hopefully it should be fully painted in the next few weeks.
I have gone for a porsche 911 colour off the 2009 range: Sport classic grey.
All feed back good and bad welcome.
I will keep a close eye on this build thread good luck!
Austin Line said
I can see this caddy is going to be a show stopper if all these colours come together, have you looked as far forwards as seats? A front bench seat would look 1st class in my opinion…
Ive not really considered seats yet, not really a fan of bench i would prefer bucket seats but we will have to see how far the budget will strech
Can I ask how you knew where to put the engine mount on the left hand side as you look into the engine bay, or is it obvious when engine is some where near ……
Any info would be much appriciated
I am under the impression that my mk2 gti block will fit into the existing place with some new unrated mounts.
83 Candy White Campaign http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-mk1-golfs_2%2Fmk1-golf-restoration_2 89 Caddy pick up http://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=projects%2Fyour-other-cars-and_2%2Fcaddy-barn-find Mk1 Scirocco project completed
Recently I have had chance to put some time in on the caddy, a few pictures of the upgrades and work done.
Firstly I got my own spot in the workshop:
Also most of the body work is complete, finishing paint on Tuesday, just the rear quarters now to finish:
The front struts and hub assembly is now fitted in place:
I have dug out some big 310mm brake discs and calipers, which is where the problems began. As you can see from the pics below I discovered my hub is not from a MK1, so I would
appreciate any help with discovering what they are from? Also the disc I have appear to fit however the fixing screw the holds the disc in place does not have anywhere to screw into on the hub, would this be of major concern, I am debating just tap and dieing myself a fixing hole.
hubbadubba said
Caddy looks sweet mate, good shell ya got there, just taken ownership of one myself actually so I'll be watching yer progress for tips, mines a good shell rust wise but I'm gonna need a cement mixer for the filler needed for all the dents
Yeah the shell was the whole reason for buying it really, I can sympathyse with you about dent repair, I detest bodywork and fixing the dent damage in my first caddy really made me push for the one I have now.
I have expanded the VW fleet though in the mean time, I got my girl friend a set of wheels to call her own, a bit of paint work, some hours cleaning, some BBS rims and shes ready for the road.
That makes it three VW's now then, I think there may well be a pattern appearing here.
