2E Carb?
(In Topic #164904)
ive had my mk1 1.8 clipper about 10 months, when i got it it had been sitting in a garage for a few years so expected some work. Ive alwas had trouble with it cutting out on my, first i though it was electrical so i have replaced
rotor arm
dizzy cap
leads
ignition coil
while these seemed to make the problem better for a while it didnt go away completely.
i was then told it was fueling problem, i noticed the filler pipe was rusted through to replaced:-
fuel filler pipe
cleaned tank
replaced inline fuel filter (a few times, now stays clean)
fuel pump
I have also changed air filter, oil, oil filter, cam belt add pully seals as one went pop.
The car dirves better than ever.. when it wants to.. i will still be driving along and get a judder and it will die, if i wait 30 seconds it will start again and may do another 5 miles, or 5
yards. Its now getting dangerous breaking down in places where i cant pull over so i cant use the car and really a, stuck.
Ive been told it sounds like the 2E carb i splaying up.. i went to clean it and noticed the choke plate moves parts to the right (green arrow) but they dont seem to do anything.. like there should be a spring there or something, can anyone advise? or if anyone has one take a photo where the green arrow is looking for me?
i have seen a few 2E carbs on ebay from fords and other cars but not sure if they will fit? i take it i need one from a 1.8 engine and a lot dont say what engine thier from. I cant afford a weber at this stage.
There is defiantly somehting not rite with the carb throttle plate if any 2e carb owners can help.
Iv managed to get a new carb which ill be fitting but im unsure of the engine size its for so will be swapping over the jetsafter a good clean. Any other advice on this would be great
then when you refit note there is a notch in the choke housign that lines up with a notch on the carb to ensure proper alignment, plus make sure the choke actuator in the housing is hooked over the choke flap lever correctly.
once you remove it you'll see exactly what I mean its all self explanation
to change the jets you have to split the carb, etka has some numbers but not sure what they refer to:
1.6 - 1st stage 110, 2nd stage 127.5
1.8 - 1st stage 105, 2nd stage 120
basicly i got the new 2E carb and its different! so couldnt use the hole thing, i split them both and used the top but the vacuum hose that goes from the top of the carb at the back to the air box is now gone.. and like i say there is a different mech on the auto choke, it runs but my throttle cable pedal grommet broke so now waiting for another one to try and test it. this carb also doesnt even have a hole for the airbox clip! ur the only person from several forums who has helped at all, seems people say get a webber because no one knows anything abou them, really am getting fed up of it.
the one in your pic is deffo a 2e2
