MK1 Golf GTI - Warm start problems
Yomp said
my motor has no problem starting from hot regardless of what fuel is in it. So what's the difference between mine and yours?
They shouldn't need super to start from hot. How do people in Ireland cope? You can't buy super in Ireland.
If my car had a problem it wouldnt start on the button every time. I have no idea why yours does start on the button when running 95 when its hot maybe you have a set of heat sheilds fitted round your exhaust. The ur quattros also had hot start problems when unleaded was introduced & the audi gurus got round this problem by fitting blade type fan over the injectors that cool the braided lines down for a few mins after its stopped preventing vapour lock, when we moved over to electronic injectors vapour lock wasnt such a problem.
baz
I had no returnvalve on my fuelfilter, which meant that my pressure inside the fuellines and fuel distributor fell instantly to 0 bar.
Now with a new returnvalve i have 2.5 bar for almost an hour.
Finally i got rid of this problem! Yay!
MK1 Golf 1 GTI Pirelli
Did you manage to rectify the problem in the end w65 pirelli?
Yeah i did.
I fitted the accumulator but without luck.
Then i found out that i didnt have a returnvalve on the fuelfilter, which was why all the fuel pressure went back into the tank when engine was off.
Then my injectors were leaking like mad, i swap them around so that the worst were on the shortest fuel line and the best on the longest ones.
(Took them all out, made a rig for my air compressor and tested first with 1 bar when 1.2, 1.3 bar and so on undtil i saw bubbles in the fuel)
After all this i start OK on both cold and warm. My injectors can in some cases still act up, and only go on 3 cylinders in the first 5 seconds, but that is 1 out of 20. But they are cetainly up for a swap when i have the money for some new ones
That can pretty much tell you everything.
