Replacement DX won't work
Last edit: by Birtymeek
Why did I start this
failing that you will have to start from the begining with timing, checking its all ok and the valves are in the right place when the marks are lined up.
There is a good how to on here if you search for it.
Last edit: by pearcestu
That lead is then connected to cylinder 1
the rotor arm turns clockwise (right) so the next lead round goes to cylinder 3 then cylinder 4 then 2.
that should get it started provided all is ok with the timing marks and the engine is correctly at TDC.
you should have a white 1.8 bar switch in the filter housing, and a brown/blue switch in the side of the head.
one thing, how long has engine been sat, and was it drained of oil?
You need to setup the dynamic timing when the engine is warm then adjust the mixture and Idle once you know the timing is correct. Good online tutorials if you search google.
Your coolant light could just be an airlock or faulty sensor if you try bridging the connector wires that should tell you if the sensor is faulty or if its a wiring issue.
