Electronic Ignition
Cheers again
factory ignition live on mk1/2 electronic ignition isnt fused though
Has anyone fitted the Pertronix unit (I have the 1847V unit in my 1977 Beetle 1.2 and it has worked perfectly for the last 8 years).
For coil check the wires on positive side, if the power feed from fusebox is black then it's a full 12v coil. If it's purple/white it's a resistance wire so lower voltage, and you may need to replace this wire depending on what coil is included with your kit
I have a blac and yellow wire in the engine bay near to the distributor that is not connected to anything? Any idea what it would be for?
