Windscreen Wiper Motor Replacement
rubjonny said
they are understandable if you know what to look for
Which I don't being a VW noobie
I can always hassle you Jon via PM though
191 - mk2
1h0 - mk3
1j0 - mk4
1k0 - mk5
535 - corrado
357 - passat
etc
also, the 3rd digit can change to show handedness, eg:
1h0 = non specific
1h1 - lhd
1h2 - rhd
1h3 - 5door non specific
1h4 - 5 door rhd(?) not seen any parts that are 5 door specific AND rhd specific, so this is a guess
earlier than mk3 it was slightly different, so
191/171 - lhd or non specific
192/172 - rhd
193/173 - 5door
etc.
the middle numbers refer to position on the car:
1xx - engine
2xx - fuel & exhaust
3xx - gearbox
4xx - front axle
5xx - rear axle
6xx - wheels & brakes
7xx - pedals and controls
8xx - body
9xx - electrics
next 2 digits refer to certain parts of the group:
905 - alternator
919 - engine sensors
955 - front wipers
etc
the last digits are part specific code. letters generally refer to a modification of the part, and 9 times out of 10 different letter = totally different part. sometimes it refers to a supercession, so xxxB can be replacement for xxxA, but not always!
X at the end of a part number refers to an exchange part, so for example 443 615 123 F is a front G60 caliper housing, 443 615 123 FX is the exchange part number for it meaning if you give them one back you gets some moneys in return
rubjonny said
cheers dude! the above gradually becomes clear if you use ETKA all the time like me
How does one obtain a copy of ETKA for home use?
smudger1980 said
entersoundman said
No mods at all, I took it off with the wiring plug from the mk3 and put spade connectors on, bolted to the linkage and plugged them into the plug on my mk1, leaving off the mount which is not on the mk3 motor as its on the linkage.smudger1980 said
Does this require any different mods to the MK2 one to make it fit the MK1?entersoundman said
If anyone is interested the mk3 part number is 1J0955119
Cheers for the info mate. Does this one HERE on eBay seem suitable ? Don't want to get the wrong one.
Help appreciated.
Smudger
Yeah that would be fine. Or If you want the most straight forward go for one with the mk3 plug. Have a look at item number 330905670164 comes with wiring and linkage.so could sell linkage on. Cut the wiring after the plug (ie right hand side)and match the wires up to the same colour on the mk1 plug.
'89 Clipper Cabby White Light Mod's
Audi A3 2.0 Tdi Quattro S line Light Mod's
Does anyone know the wire colours for the MK2 or MK3 motor. I have both motors, don't ask! When the Mk2 was wired up it kept blowing the 15A fuse. I just bench tested it out of the car and it runs fine, if i run a wire from the -ve battery terminal to the 53b terminal on the motor and the +ve wire to the 31 or 53 terminals on the motor it runs at the slower and quicker speeds?
I thought i'd read the wiring diagram correctly and wired it up as so:-
- 53a (black/grey)
- 53b (green/yellow)
- 53e (green/black)
- 53 (green)
- 31 (brown)
'83 formel e
vrupper: yep thats what I have in my diagrams, i wonder if the wiring in the car is shorted? I'll try to fig out a wiper plug later and piccy it for you
'83 formel e
'83 formel e
'83 formel e
