which brakes to put on my mk1 GTI
i need help on which brakes to use to upgrade my mk1 brakes.
Some passat ones are the same if the mc is stamped 22 then the chances are its a 9 inch servo.
I got my 256mm setup inc carriers from the scirocco register last summer (16v 'rocco calipers and carriers). The guy I bought them from had bought them in the US and reckoned they were still available there. Might be worth following up? The calipers are Girling 54 with 'Made in USA' stamped on them.
Sent from my SM-N975U using Tapatalk
Re:
Thanks! Turns out the previous owner didn't even put brakes back in the drums..abfmk1 said
No…
Re:
There aren't any lines running back to the drums. I couldn't believe I didn't notice that when I took the tire off. I think I'm just going to leave it be. I drive the car in the neighborhood just about every day and it stops just fine even when heavy braking.paceman said
Surprised there isn't fluid leaking out of the rear brake cylinders if there are no brake shoes in place. Cylinders pop right out (learned from experience!).
