Right hand cornering and cutting out
plus it means i can drop the rear end out and clean and paint it all while i'm at it
Life Member
Life Member
Perhaps this lot had something to do with this!!!
We fished quite a lot of rust out of the tank, probably left over from when the previous owner did the filler neck. The bottom was also 'hoovered' with a natty device made up of a tube, flier and a fuel pump. The other side of the fuel pump had a hose that went back into the filler neck to complete the cycle!
We'll see if that little job solves the problem.
Just the hot start now!
Life Member
Fingers crossed!!
Life Member
Length of small bore petrol pipe connected to a filter - a large one and then a fuel pump connected to a car battery and then a length of pipe out of the pump long enough to reach the filler neck again.
The small bore pipe ensures that it could be aimed at specific areas in the pot.
Once the pot was 'hoovered' out the new filter was put n the car in the engine bay.
The old one had a lot of sandy rust in it. It must have helped getting rid on all that!
Sorry, not pictures of the device!!
Life Member
