Return of the hesitation...
(In Topic #151983)
when im at higher speeds accelerating i feeling a loss of power/judder or hesitation causing me to slow down and pull over into the slow lane..
Looked at my dizzy just from the outside and noticed a slight oil leak.
think this may have caused the return of my recent timing problem?
thanks
cf_emoticons__BangHead:
New to Golfs - All Help Appreciated!
Then noticed the carb cleaner leaking out of the base of the carb and onto the manifold..
So i think this 4 month old GSF quality part is now split..
Think that may be my problem?!
oil leaks past the base of the dizzy when the o-rinng fails, shouldnt affect the timng though unless the dizzy itself is knackered.
does it happen if you're cruising along the motorway and put your foot down to overtake? or if you've been accelerating for a long time, up a big hill for example? is it always at a certain engine speed or a certain throttle position? when did you last change your fuel filter? does the hot air flap work correctly? it could be a few things, need a bit more info really..
Take it easy ; )
I've replaced the carb flange also this past weekend still does it.
Any ideas?
you should take it to your garage and ask if you can use the gas tester in the MOT bay for a few miniutes, offer to chuck the guy a tenner if you need to - I did this after fitting my weber and at first my CO was 8.3%!! which explained a lot of my drivability troubles, tweaked it down to 1.8 at idle and it drives like a dream!
have you checked your float level? or fuel pump? one 'quick and dirty' test you can try is to blank off the fuel return and go for a drive, if ts fixed it you can look at the pump and float, if not then your issue lies with either jetting, dirt, or timing..
Take it easy ; )
Ill let you know my progress, thanks!
and definitely get it on a gas analyser - that'll tell you everything you need to know if you can be arsed getting down with this science… http://www.autoshop101.com/forms/h56.pdf
Take it easy ; )
MK1Morley said
Just to be more specific of the problem, it's when the second throttle valve opens and prolonged acceleration or sudden happens. It will then start to hesitate.
sounds like its going lean on the main circuit in the second barrel…best way to confirm this is to get it on a gas analyser - did you read the link I posted in my previouus comment? read through that and get it on a gas sniffer!
Take it easy ; )
Just an update,
Stripped the carb, cleaned all that could be cleaned!
And still no success,
A perfect description of the problem is prolonged acceleration opening the second throttle chamber on most occasions causes it to splutter. And during the "spluttering/hesitation" it will pop and spit from the exhaust.
I'm getting fed up of the clipper now and I really don't want to be
So I adjusted the mixture and it still does t stop the problem, I'm going to block off th return next…. If this works. Faulty fuel pump maybe??
MK1Morley said
SUCCESS return clamped off and she runs like a dream… Hmm now to actually find out what's not working!
I've done the pump and still no success … next I'm thinking the filler and tank need to get changed, I'll be changing the vapours operator too- convinced its crud in the tank.
Where did you tap the return thinking of trying this first but don't want to ruin things- have you got a pic?
MK1Morley said
I literally got a set a grips and clamped onto the return from the swirl pot and went for a drive! I'm thinking my problem is the pump! I will get a pic ASAP
Cheers mate. Just had my pump changed so thinking rust or if not, the return is having an impact….somehow…
