Setting up timing, - pics
after new head gasket
Think I have a little air leak somewhere. Changed the idle screw for one I found on an old part and it has made a difference - I can adjust the idle speed now!
Went down to the dealeds for a new idle screw but they don't do them now.
Does anyone know if an 'O' ring from the plumbers merchants will replace the rubber bit?
Its running ok, but a little lumpy and the idle hunts a little.
I went to set the timing with a gun as above posts, and noticed that my flywheel has obviously been replaced at some point as it has an "O" stamped. No problem there.
The problem is that the "O" moves around whilst using the timing gun?!! It stays in one place (the right of the hole) for a couple of seconds, then disappears completely, then appears on the left of the hole for half a second, then returns to its original location. And so on and so on.
Can anyone shed any light on whats going on?! Its gone right over my head
Many Thanks
it may be the dizzy is a bit ropey allowing the ignition advance timing to move about randomly, or as i say the idle coudl be unsteady which never helps
check all over the engine carefully for air leaks, vacuum pipes and the flange under the carb are prime suspects
