Alternator charging problems
(In Topic #149779)
I wonder if someone can assist.
I have an issue with the alternator in my MK1 16v at the moment where it will not charge the battery. I have proved this by putting a mutimeter across it and there is no voltage coming from the alternator at all.
I subsiquently bought another alternator and fitted that with the same result as above.
I have read all the threads regarding the blue wire and the warning LED on the dash and that is my next area of investigation as the dash warning LED does not illuminate at all anymore.
My question is, if it turns out to be the LED where can I get a new one from and how do I fit it into the dash?
Any help would be much appreciated.
Cheers Bob.
Mk1 golf gti campaign… 16v ish…
MK3 gti 16v
is the mk1 rusty? depends what you mean by rust….
MK3 gti 16v
I have been tinkering this morning and have done as said above and this has proved the lamp still works!
I have cleaned all terminals on the blue wire and stripped the black plastic protection to check for breaks and all is ok and double checked continuity with a multimeter.
Still no light on the dash whatsoever!
I am stumped at the moment!
Do you know what inside the alternator controls this little circuit if anything?
MK3 gti 16v
MK3 gti 16v
MK3 gti 16v
MK3 gti 16v
Cheers mate appreciate the help.
MK3 gti 16v
MK3 gti 16v
rubjonny said
maybe try ruinning a fresh wire from the blue spade to the alternator d+? if it still doesnt work then that would suggest the alternator is stuffed, or maybe its not got a good earth contact. it earths via the block to the gearbox then back to the battery -ve, if the block/alt has been painted then that would stop it working. to rule it out run a jump lead from the battery -ve to the body of the alternator somewhere
Hi John,
I've tried the above the light in the dash works when I earth the block near the battery so i guess as you say the alternator is stuffed.
Could you tell me what size allen key/star bit I need to get the alternator off (the one through the cambelt cover) as I can't find anything to fit in my socket set?
Thanks John.
before you take the alternator off though, try earthign the blue wire ring terminal as well. if light comes on then yup, duff alternator. if not, the blue wire is snapped somewhere between the battery plug and the ring terminal
if the bolt is rounded it is possible to unbolt the lower bracket from the engine with alternator still attached. dead fiddly but you can do it!
Robbo said
Hi John,
Thanks John.
I believe it's a 6mm Allen key you need, but I stand to be corrected :
took the car to the aternator recon place he gave up after 2hrs trying to get it off
So I'm back home from work so going to try again think it is 6mm now I've got the cam casing off looks like as Johnny says I might be able to get the bracket off the block not sure how the allen bolt would come out tho?
Will also try a blow torch any other advice guys ??
attempts have been made to chisel the bolt head to get it started.
So I'm thinking perhaps an angle grinder to cut the alternator off then cut through the bolt and remaining bit of alternator body??
Or could a garage use oxy to cut it leaving a stub of bolt to get some grips on?? Any other options you can think of ?
no need to mess about with grinders and such if the alternator is stuffed anyway!
an alternative is go mk3 alternator setup
Going to have another go in 5 mins the bracket 13mm bolt won't budge either but thats more trying to get some leverage on it thats the probem.
How many bolts hold the bracket on (2 maybe) or do I have to remove the cam belt & pulleys etc to reveal a few more bolts??
Checked the alternator its had it so if I can get the bracket off then I'm sorted I can either get this one refurbed a new one or 2nd hand one will any alternator fit the bracket I have or is each type a different size etc.
Thanks John.
Update….
Got the alternator off with bracket attached the hardest bit was finding where all the bolts are and gaining access so all being well i hope to have it refurbed at the garage in the morning.
Lets hope I can get a new allen bolt without too much trouble. Thanks for the advice guys
Last edit: by Robbo
I've even watched that video in German… But mines not budging :/
WWW.DUBSHIRE.COM
