Phils Mk1 Golf GTD Build
Slow and steady wins the race
you from round here then?
Pipsical said
Yer the old dixons place.
No Mate
I live in Sheffield , I worked for Dixons , now Just Car Clinics and used to go over to Scunny to look at cars.
Do you need an Intercooler for the Golf i have a few here from when we did my lads conversion.
new enine in.. But removed again to weld in engine mount in place.
tried the best i could to straighten out the front panel, maybe replace it in the future if i can find a replacement. Few pics to come :-)
this is both the GTD engines, borrowing a few bits.
ready to drop in..
The old 1.1 out and a big gap..
Engine mount chopped..
Front panel looks a bit better..
getting there, reason its not got the belt on is i forgot the altinator bracket so need the bloody pump off.
Last edit: by Pipsical
Just got to make a rear gearbox mount as the one i have doesnt fit. Hopefully the gear linkages we made work too.
Just need a throttle cable and clutch cable off a diesel as mine are different.
Also decided to buy a new front end as VW heratage sell them for £94. I may run without a bumper till its sorted as mines all bent.
TBH denting the front made me wanna swap it out as it's a little rotten in the drivers side corner, currently got filler in it so better in the long run to remove and get a fresh one in.
Hopefully the bits i need are in stock or quick delivery from parts place.
had to borrow a passenger drive shaft as mine was from the 4 speed so it was about 30mm longer so couldnt get it in.
the caddy radiator is too long.
the coolant pipe work i have were all wrong.
the starter motor was lazy and wouldnt give the kick it needed.
but on a positive note i wired up the glow plugs to a switch and old choke light.
Wired up the stop solinoid on the pump to an ignition live and it did turn over and made the right noises.
made up coolant hoses to go into the radiator.
fitted the drive shaft and made up the gear linkage with the 5 speed steering rack.
ive also ordered a FMIC and pipework today.
some messy pics
Now ive fot a few questions..
should this have a hole in it?
and what the hell is this for?
picture of them both in situ..
hopefully tomorrow will seee it start :-)
The 2nd pic is a dump valve,mk2 tds had this,it opens at 9 psi to dump exess boost back into the intake pipe
Bert
Major issues :-(
Ive just looked at my mates caddy.
Seems the problem i have is the remote on the car is wrong.
As i go forward with the gear stick the rod goes forward.
On his when going forward with the gear stick his rod goes back.
Looks like i need a big block remote :-(
Spent all day trying to figure it out, hopefully a they are easy to swap and i can find one.
Got a starter motor.
New stainless steel downpipe.
Big block gearbox remote - thanks funk-star.
Boost pipes.
Decided im going to run a gti radiator so ive got a expantion tank etc as my 1.1 had a top fill. But im not worried about cooling atthe min.
Fitted the radiator and all the pipework except a header tank as i need to weld on a bracket for that to sit on. Using my 'box of sh!t' i managed to get it all together haha.
The cars turning over and firing, but not running yet. Im thinking as its a brand new engine it will need to be bump started as there isnt enough spin from the starter motor. But i cant do that because i have no brakes.
Also got the FMIC fitted and sat very well, im very happy how well hit sits.
A few pictures to prove ive been out in the cold. Not far of now :-)
