Jimbo's Mk1 Golf 1.8t
doesn't look enough to get a stud extractor on it?
easy out type drill looks to be the only way? plenty of plus gas before you go anywhere near it! soak it for hours/days!
my dad finally got it out, had to buy an extractor though…
also made the skid pan;
chrome toooooooooooooooooo!!
Now rolling again. Put the rear hubs/brakes back on, but added some negative camber so the tyres wouldn't scrub like they did on my 300mile trip home!
Dropped the rear coilovers down a touch too. Only problem is, the fronts are budging :( Is it ok to use heat on them?
and any know what the hell this is?;
(the component, not the bigger pipe)
seems to go into the fuel tank
Photobucket
just need to lower the front!
Photobucket
heat is fine on coilovers, plus gas is useful but not  at the same time ;)
also a hammer and a drift will certainly get them moving
Cheers man.
Quickly re did the rear camber this morning- as I had put the washers in wrong-
Love it!
Going to attempt to get that front lower tomorrow!
Photobucket
The more I see those wheels the more I like them :)
broke down again :(
think i may be leaving this mk1 at home in Derby at this rate!
Photobucket
What happened mate? Sourced the cause of the breakdown?
Think it's over fueling.
Is the only way to sort these engines with overfueling through computers? Cheers
Photobucket
its my old car , if its overfuelling there must be a problem somewhere , as the mapp wont change on the ecu , have you checked the air flow metre ?
Airflow meter?! Dumb question - Where's that?
Haven't really checked anything other than taking one of the spark plugs out, as it would start either, after it conked out on me…
Basically after a bit of fun, the engine randomly stopped running- came to a stop and it wouldn't start. But it started today straight up?!
Photobucket
MAF
sensor that plugs into the air filter
What do I need to check? If the sensors nakered?
Photobucket
get car running, disconnect MAF, does car run same,better (shouldn't be better lol) or worse?
Awesome! Cheers. Ill try it tomorrow.
Photobucket
arrow in red
what size is it? best to get your  self a new 1. atleast you know its new as this maf can cause loads of faults and errors
I had loads of proble with my 20v engine in my audi, turn out to be the MAF and crack senor....
Tried what you said- engine ticking over and pulled the maf plug off and the engine cut out…
Anyway someone's coming to check it out tomorrow- fingers crossed! Cheers
Photobucket
Thats sort of good news, does it have vagcom capability?
Yeah think so. Read on the Internet about wiring in the obd 2 16pin plug, with just 3 wires? Pretty sure I've found it… So fingers crossed he'll find the problem tomorrow!
Photobucket
