Good DA Polisher ?
Good DA Polisher ?
Hey Guys
Been meaning to invest in a Dual Action polisher for a while.
I'm not on Detailing World or anything and dont wana get too OTT into my detailing, but do want something to save my hands when giving mine a good cut and polish and hopefully allow me to get a more consistent finish over the whole car
Originally i was gona go for a meguiars G220 V2, but a member on the forum has let me know they have not lasted long for him
http://www.cleanyourcar.co.uk/meguiars-g220-v2-polisher/prod_409.html
so he has suggested the Das 6 pro
http://www.cleanyourcar.co.uk/polishing-machines/das-6-pro-dual-action-polisher/das-6-pro-dual-action-polisher/prod_673.html
anyone else use simmilar machines that they rate?
Rich
1.8T CABBY
whats the main difference between a normal rotary and the dual action machines as well?
Are they just more controllable and less likely to burn through paint?
Rich
1.8T CABBY
Rich
A dual action. It means that the pad not only spins in a circle, but it also oscillates so it's much safer to use. Also it generates far less heat than a rotary polisher.
1990 MK1 Golf GTI Cabriolet
1983 MK1 Golf Campaign
Thanks chrissy
So anyone invested in one? has a recommendation? used the above machines?
Rich
1.8T CABBY
I have a Porter-Cable 7424Xp which i've have for about three years. Great bit of kit! There is one on ebay Link the older model.
Alex @ Elite car Car has never let me down for stuff and always given great advice too.
http://www.elitecarcare.co.uk/
Could be worth an email or call?
If I remember the Detailing World discount code is DW at the check out when ordering online.  :wink:
Mrs Choc Rolls Stock!
Hi Rich
I detail for a living and use a flex rotary. If you are new to detailing and machine polishing then stick to a dual action polisher it is much safer. I would check out a Das pro 6 it is a fantastic machine and gives decent levels of cut. You are more than welcome to try these machines at our unit, but you are in Bristol and I'm in Nottingham. Oh yeah  sell me your car Lol
get the meguiars g220v2 ive used mine lots over the past year and love it to bits.
euro car parts sell them .expensive there but if you enter the code LASTCHANCE25  this gives you 25% off everything…..you will need a pad failing that theres lots of good kits on ebay for around 150 quid made by kestrel known as the das2,,,from memory the difference in this and meguiars is the meguairs has a soft start and no load speed.
Dont bother with a dual action rich they suck,if your paint is heavily swirled it just wont cut the mustard and you will end up buying a rotary anyway! I also use a flex not that im suggesting you splash the cash on one just yet,as long as you get a variable speed you should pick one up at a reasonable price.If burning through is your worry just use a polishing head and a milder polish/cut to get the feel of it,im only just down the road (in a way) lol and would be more than happy to show you the ropes.Anytime brother.
disagree ive tried the das6 pro and the megs i also use 3m rotaries and the megs is so much nicer to use
Ever tried polishing out wet sanding or scratches with a dual?
I've done a bit of polishing here and there, wet and dry is a favourite method of dulling/removing deep scratches.
Deep scratches removed with wet and dry 2500/3000 grit emery paper, then removed with a DAS6 pro
Before and after
Finished article!
1983 Golf 1.3 Driver:
DAS 6 Pro for a DA polisher.
I was looking in to this a while back, I ended up going for the cheap and cheerful silverline rotary, as that came back the most recommended.
I watched a YouTube vid of a couple of guys intentionally burning thru paint. You get loads of tell tale signs before you do any ireversable damage, it smokes, the pads break up.
For the ammount of use it gets the silverline does the job very well..
what you go for in the end rich?
