Clipper running issues
1.8T CABBY
1.8T CABBY
Got around to fitting the new fuel pump Saturday. Also removed the vapour trap and blocked off the return fuel line.
It took a few turns but finally fired up, I went to go for a quick run around the block but got about 20 - 30 meters up the road and it died again, then would not start.
It seems like its firing up and then cutting out straight away. Eventually it did stay running with the choke in but when I gave it a little rev it died again. So now its turning over, firing up then cutting straight out.
The fuel filter is still clean, fuel getting through ok.
Should i now whip the carb off and get a refurb kit or just get a new one from Weber and see if that works?
Not sure what else I can try on it?
Any input welcome and appreciated.
Marcus
or do what i always wanted to do with it and do a 1.8T conversion :-)
1.8T CABBY
1.8T CABBY
1.8T CABBY
1.8T CABBY
Secretary
Mate sorry to hear about your problems, I hope you get to the bottom of the problem.
Haydn
Regional Host South Wales
No worries mate. Just one of those things with older cars and part of the fun of owning one.
As I said to Rich, I have sorted a new carb from Weber and a new rubber flange. I'm going to fit them next Friday as I won't have time this weekend. Fingers crossed that will sort it out.
I've had a read of your thread too, it sounds very familiar!
Good luck with getting yours sorted too mate!
Will post an update as soon as new carb is fitted and fired up!
Marcus
Secretary
Yesterday i checked the dizzy cap and noticed that the rotor arm was about burnt out, so ive changed them over and overall the car is running better, although not 100%. I dont know if the timing is out slightly or whether the weber twin choke (32/34 dtml) is needing to be set up correctly.
Finally got around to fitting the new Weber last nite, held up due to losing the shoulder stud that goes into the mounting plate! Weber got a new one out to me the following day - nice one.
It all went on very well and back together fine.
One turn of the key and she fired into life and was running fine, so lowered the tickover with the choke and left to warm up. Then set up the tickover and went for a quick run. It did seem a little bit more responsive too.
I only went about a mile or so last nite after about 15 minutes of warm up but it all seems to be running very nicely again!
I am going to go for a proper run early Saturday morning just for peace of mind but fingers crossed etc. it's looking good!
I will have a look around the old carb at the weekend too and check for muck inside.
I just want to say thanks to everyone for their help and suggestions, hopefully I'm all sorted and running again!
KennyE, I'm going to put a new dizzy on too at some point, just for another peace of mind. Probably overhaul everything at some point. After all, it cant hurt!
Macca, it sounds like you're on the right track too mate! Good luck it getting yours up to 100%!
Once again, thanks everyone! All the help is much appreciated!
I will let you know how the drive goes at the weekend!
Marcus
great new to hear my old baby is running sweet again
We are attending a show at Berkley castle in gloucester at the end of the month where we got best club stand last year, and a show in Malvern in October
for Berkley see here
The Mk1 Golf Owners Club
for Malvern see here
http://www.vwgolfmk1.org.uk/modules.php?name=Forums&file=viewtopic&t=121401&highlight=malvern
be great if your free and wanted to pop down, feel free to po your name down
Rich
1.8T CABBY
1.8T CABBY
