MK1 golf KR
MK1 golf KR
paul_c said
So you'll need the gear linkage for a manual 5 speed too? I think you might need the steering rack also (can't remember if auto steering rack had the bracket for the linkage).
Gearbox can be 'converted' to 90mm shafts by swapping the drive flanges on it; or seek 100mm shafts from a later cabby and make the small mod or use later hub carriers too.
Don't forget KR gearbox has a 24mm input shaft, most other 020 gearboxes including all in Mk1 have 22mm input shaft - but if you're using a KR too, your friction disc will accept the 24mm shaft already. If you're mixing and matching, you need to make sure it does match etc.
I have a gear linkage off a 5 speed , it runs underneath and on the end has splines ,will that be fine to use with the kr box .
Yeh i might aswell find the 100m shafts then and grind the lip down instead of getting hubs aswell .
Have a look at the thread I did, I think its stickied, somewhere in there is the part number for this pulley.
You might have a slightly different pulley arrangement though - so check first.
I have also heard you have to grind the o/s engine mount off the chassis leg and flip it upside down and weld it back on .
What i was going to do if this was right was grind it off attach it to the engine , lower the engine in and see where it has to sit and spot weld it in then remove the engine and get it in properly .
Get sum pics up web u start mate
Dan
your gear linkage will attach to the new gearbox so no need to swap anything other than get new bushes
you will need a 16v brake master cylinder and servo as the dizzy will hit the mk1 one. and flip the reservior round
your std mk1 brakes should go under 13" steels ok if not some spacers may give you the clearance needed.
your wiring could cause you some grief if you want to convert to injection but you may be able to use the corrado engine loom in your mk1 fusebox as i think they are the same.
the non pas water pump pulley is obsolete from vw and i cant find any for sale on the net so you may need to tack weld the free pulley.
paul_c said
Dont remove the engine mount off the chassis leg, its already in the right place! You've got your wires crossed somewhere, thats only necessary for small block (1.1 and 1.3) cars
Good job i didnt do that then :/ this sounds like its getting better but will more than likely come stuff somewhere else
sporttrucker said
90 mm driveshafts and hubs are fine if you swap the flanges on the kr gearbox to ones that fit your driveshafts remember you will need new seals. i can help you make up a tool needed to do this but you will need good circlip pliers
Thanks for answering most of my question , been a great help and alot taken off my mind lol , tbh i think atm i have all the answers in need untill i start getting this together , i will be sure to make a thread and hopefully help out some other people who wants to do this thank you so much !
the only thing is you need an 8v king lead as the kr one probably wont reach. i had 2 sets of kr leads handy and i managed to pop one of the plug ends off and fit a dizzy end, some leads the ends pop off so the above is possible.
i tried the above flip reservoir thing but i found the clearance issue was to the master cylinder rather than the bottle, the pipes were touching on my cap. for some reason in the pic above he has more room but on mine i had no choice but to go the abf cap route
see my mk1 16v cabby build thread lots of pics in there
