Atommans Mars Red 1.1 Project
Next time your down the factory (JP's) let me know if your still after one.
Made it out of T6 Aluminium , I've got some ali tube to for the pipe work.
Now just need to get the engine in so i can work out how long/angle to make the maifold.
1100 mount chopped off moved turned upside down and rewelded on in the right place for a big block
Engine finally ready to go in , did have to take the header off as it was never gonna fit with that on.
Supriseinly didn't take to long after about 10 mins it was in and bolted up to all the mounts
Got the exhuast Manifold bolted back on to and also the gear linkage and the Rad in and started plumbing it all back in.
I can start measuring now and start welding up my carb manifold
does anyone know what clutch cable i need ?
I have just made my old one fit at the moment and it seem to work, io did have another one with the engone and box but the end is wrong on the pedal side.
Liking the cnc'd inlet mount, wish I was still a machinist sometimes!
As for clutch cable, you can use a mk1 cable, gti for example as 5 speed. I used a mk1 diesel 5 speed cable as it bends 90 degrees as it leaves the bulkhead, and you can hide it around the back of the bay. Though I think the pedal action is a little stiffer because of the bend, but not too bad.
finished mocking up the inlet manifold for the bike carbs. so fitted it to see what it was like for clerence to exhaust etc
Also managed to get some steelies that clear my brake upgrade im gonna do, but they are only 6J so a bit of machining and
Now in two bits
just need to offer them up to the car and measure how much i can Band them
im thinking 7's and 8's like my compomotives or maybe 8's and 9's
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
allana13 said
Nice Project mate….. Have you changed the engine or kust modified the existing engine…
Yep changed the engine, it was only a little 1100 and i think the head gasket was starting to go and it didnt like the motorway on the way to work with the 4 speed box.
one of my mates had a mk 2 gti engine and box for sale so a deal was struck and now its 1.8 with 5 speed
Is that your splitty parked next to the Golf?
Mrs Choc Rolls Stock!
Choc said
Looking great so far! 8)
nope not mine a friends I look after, it a OG RHD UK doormobile conversion, its pretty nice apart from his choice of colour , but each to there own,
Ive had a few splits thou in my time
fitted up centre console i was given, rev counter and oil trmp and pressure gauges, just need the sender for the pressure gauge,
bike carbs are on the back burner as have'nt had time to CNC the manifold, so got this twin weber manifold instead .
manifold fitted had to take the exhuast off first then refit it after bolting it up, fuel lines all plumbed in to. car started first time
just need a blanking plug for the lambda sensor and tweak the timing a bit now, sounds awsome though 8)
Also started to fit the front arches and twin light grill and duckbill, had to wind up the front coilovers as the spoiler was on the floor
I do like the single grill better but driving round the lanes in the dark round here i need the extra light,
just need to machine the other driveshaft this week and fit it and maybe then a test drive
turkeys on and wine is open
Other drive shaft is now machined up and fitted, carb's are on, linkage is working but need to come up with a better solution as its a bit heath robinson
also need to fit a diesel clutch cable asa it fouls one of the filters at mo,
heres the first start up timming only set roughly at 0' to get it going
took it out for a quick test drive and then needed to adjust the gearlinkage as 1st and 2nd were in the reverse gate.
with a bit of tweak to the timming and the linkage I took it out yesterday and gave it a bit of a test run in the old industrial estate in between rain
seems to go pretty well and pulls like train, bit lumpy on tick over but thats to be expected with a cam
exhuast is a bit leaky from one of the joints and there is an little air leak so a bit more work and i will take it up the rolling road and set it all up properly
Merry Christmas All
so after a bit of plumbing at the side of the road i bypassed the feul pressure regulator and it seemed to solve the problem.
then stooped in a mates house for a cup of tea on the way home and managed to loose the gearstrick when itried to get it in to reverse
the only bush i didnt replace in the gearlinkage was the ball on the gearstick, another job for tonight
And put some new wheels on it, In the proccess of sorting out bigger brakes so will need 15's on it,
Might sell the other 13's if anyone is interested, there 7's and 8's.
Also i have a 4 into 1 header on it and a stainless middle section with a silencer in it but the back box is way to loud,
Anyone know of a replacement thats pretty quite ? will a standard GTI back box rob it of power ?
Gary
Ive just took the 1.1 4 speed out of mine.
Keep us updated :-)
